Old 04-21-2018, 08:38 AM   #5376
Gregski
Gregski's Avatar
Re: Restoring Rusty
could someone explain to me how replacing the intake manifold gasket caused my 1 year old starter solenoid to fail, ha ha
right after I replaced that intake gasket I battled hard starts when the engine was warm/hot it sounded like the engine was fighting itself when I tried to start it when it was already hot of course I blame the long tube headers, hee hee
I share this with you, because I thought what's the deal do I have too much timing, well that couldn't have been it cause I am running less initial advance now by 2* than I was before
ok, what is it vapor lock in the carb, must be the carb - - - nope
below is a pic of my old starter (or partial pic) my buddy Pontiac Mike taught me my old starter was not a high torque starter (not that that's what the problem was, it's just that there's two kinds) when the solenoid is bolted directly down to the starter like in this pic its a low torque, if it has a long copper looking spacer behind it it's high torque (second pic)
sorry I don't have better pics, I literally replaced the starter in an ally behind McDonald across the street from my work yesterday (Friday morning) Roadkill Style - LOL
Gregski is offline   Reply With Quote
Old 04-21-2018, 09:02 AM   #5377
Gregski
Gregski's Avatar
Re: Restoring Rusty
you guys heard of the Occam's razor principle?
I believe it's the idea that sometimes the simplest solution is the best solution.
Let me give you an example: The other day I was at an open mike event when we could not hear the performer, well after toying with the karate-okie machine it turned out that the microphone was OFF, and after the singer turned it ON, the guitar player in the background was overheard blurring out "Occam's razor"
so my point is, if your truck was starting fine and now you have a starting issue, look at the starter before jumping to messing with timing and carb etc
Motor De Arranque Nuevo (for our Spanish speaking affiliates)
Duralast Gold - you get what you pay for and this is so much nicer than the prior Value craft I had in there! truck starts so smoothly now on first kick, ha ha but I'll be honest with you I only bought this one cause it had a smaller (shorter) solenoid and I wanted a starter with the smallest form factor possible to keep it as far away from the heat from the long tube headers as possible, and this is the best I could score at AutoZone
sorry no pics of the actual starter as this was a rush job, roadside repair I kid you not, I was so proud of myself for just knocking it out rather than calling triple aye!
Old 04-22-2018, 08:47 PM   #5378
rusty76
rusty76's Avatar
Re: Restoring Rusty
You know everybody told me long tube headers and starters don’t mix well. I didn’t have any issues. And when the old starter gave up the ghost I didn’t have to remove the headers to get the starter on and off like I was told. Good luck in your endeavors.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 04-30-2018, 10:23 PM   #5379
deejaaa1
Re: Restoring Rusty
are you sure the head to intake surface is the correct angle to seal? i don't know gassers as well as diesels but heard tale of certain heads and intakes not mating properly.
Black 93 CCLB 3500 6.5 diesel, GV OD, TCI Ez-TCU controlled 4L80E, back on road 10/25/16 after sitting 4 years.
96 ECLB 2500, 6.5 diesel, auto, gone.
Originally Posted by gottattooz View Post
...68 Chevy Shortbed... guy clearcoated..and...threw glitter all over it...like he was feeding chickens!!!...
deejaaa1 is offline   Reply With Quote
Old 05-01-2018, 08:44 AM   #5380
LT7A
Re: Restoring Rusty
Man, sorry to hear about all the setbacks. I hope the new set of heads checks out good and that the starter holds up.
By the way, I heard a rumor that Heisenberg used Occam's razor to kill Schrodinger's cat. As yet unconfirmed.
Old 05-03-2018, 06:08 PM   #5381
Gregski
Gregski's Avatar
Re: Restoring Rusty
yes I am following GM crate engine specs and using GM Performance cylinder heads and dual plane intake manifold
Old 05-03-2018, 06:12 PM   #5382
Gregski
Gregski's Avatar
Re: Restoring Rusty
quick update, just heard back from the Machine Shop, one of the spare heads I brought in to them is cracked, good thing I have 2 more spare ones so they want me to bring both of those in
again the crack is in the spare head not one on the truck (we have not autopsied those yet)
Old 05-03-2018, 06:13 PM   #5383
Gregski
Gregski's Avatar
Re: Restoring Rusty
sorry double post from my cell phone
Old 05-04-2018, 01:19 PM   #5384
daddyjeep
daddyjeep's Avatar
Re: Restoring Rusty
We heard you the first time. there is really no need to repeat yourself.
Ill these troubles with vortec heads. Maybe you would be better off just getting a new set from summit.
https://www.summitracing.com/parts/nal-12558060
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 05-04-2018, 01:20 PM   #5385
daddyjeep
daddyjeep's Avatar
Re: Restoring Rusty
All these troubles with vortec heads. Maybe you would be better off just getting a new set from summit.
04 1500 crew cab
Old 05-04-2018, 01:29 PM   #5386
Gregski
Gregski's Avatar
Re: Restoring Rusty
did not mean to do that, I blame my phone, thanks for the advice, I am looking at some ProMAXX aluminum heads, about the same price for a pair as these cast iron ones
Old 05-06-2018, 02:15 PM   #5387
Gregski
Gregski's Avatar
Re: Restoring Rusty
so took the '99 Suburban L31 Vortec cylinder heads off my truck and took them in to the machine shop on this lovely Sunday morning
Here are some action shots for you so you can see how they iron powder coat them and use a huge electric magnet to test them, pretty cool
Nichols is the best machine shop ever!
Old 05-06-2018, 02:18 PM   #5388
Gregski
Gregski's Avatar
Re: Restoring Rusty
now for the bad news, both of my cylinder heads had cracks at the center bolt holes into the water jackets, now this is something I did not look for when I inspected them myself cause I was too focused on the chambers, live and learn
not sure how well you can see the small cracks in the pics but I was trying my best to point them out
Old 05-06-2018, 02:20 PM   #5389
Gregski
Gregski's Avatar
Re: Restoring Rusty
and here is the other side, now that crack right in the middle of the hole in the lower part of the hole in the pick also runs down the head so as the head heats up I assume it opens up and is just enough to slow leak that coolant, my thoughts anyway
Old 05-06-2018, 02:57 PM   #5390
Gregski
Gregski's Avatar
Re: Restoring Rusty
so I scored some brand new Edelbrock E-Street aluminum cylinder heads, a new Edelbrock Torker II Series single plane intake manifold, and a set of new ARP bolts. All for $850, not bad
not sure how the single plane intake is going to respond in a street application, but I've always wanted to try a single plane intake, so here we go
Old 05-06-2018, 03:54 PM   #5391
RDrancher
RDrancher's Avatar
Re: Restoring Rusty
That manifold will move your powerband up and you'll lose a bit of torque, but the symptom is easily cured...https://www.summitracing.com/experta...ive/answer/485
Romans 10:9 - The Truth
RDrancher is offline   Reply With Quote
Old 05-06-2018, 04:10 PM   #5392
pontgta
pontgta's Avatar
Re: Restoring Rusty
For a minute there I though I was watching "wheeler dealers"....Great stuff really cool that you are taking the effort to walk us through all the good and bad.
pontgta is offline   Reply With Quote
Old 05-06-2018, 05:34 PM   #5393
rusty76
rusty76's Avatar
Re: Restoring Rusty
Good score on the heads and stuff.
My build thread
Crossmembers CC
Old 05-07-2018, 02:40 AM   #5394
Gregski
Gregski's Avatar
Re: Restoring Rusty
yup, they are a huge influence, and I believe I've learned way more from my mistakes than my successes
Old 05-07-2018, 10:35 PM   #5395
MikeB
MikeB's Avatar
Re: Restoring Rusty
Make sure the head bolts are long enough to go AT LEAST 6 threads into the block, and preferably 8. Worst case, you may have to ditch the hardened washers.
I don't know if that's a problem with the Edelbrock heads, but I have experienced it with Dart Iron Eagle and Brodix IK heads, even with ARP bolts which, as I recall, are a shade longer than stock bolts.
Ditto on the idea to use a plenum divider, assuming there's one available for your manifold. I suspect a Performer, Performer EPS, and Performer RPM would have a much more street-friendly power band. But, hey, have fun experimenting! Next up, tunnel ram.
Mike
1969 C10 LWB -- owned for 34 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 23 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 05-07-2018, 11:04 PM   #5396
MikeB
MikeB's Avatar
Re: Restoring Rusty
I was reading through your posts and saw where you had radiator problems, so wanted to tell you about the aluminum rad with plastic tanks that I bought about 3 years ago. It's a Murray brand (same as Spectra and probably a half dozen other brands). It cost $120-something at my local O'Reilly Auto Parts store. And get this: It has a lifetime warranty!
But heck, even though it's the basic radiator for 250 and 305, it keeps the 350's coolant temp in the 180-190 range, even down here in the Texas summer heat. However, I'm sure the OE-type fan shroud, clutch fan, and brand new GM water pump have something to do with that.
Mike
Old 05-08-2018, 01:07 AM   #5397
Gregski
Gregski's Avatar
Re: Restoring Rusty
thank you for the suggestion I did not know they made those plenum dividers, though if I don't like the single I think I am just gonna splurge for the Edelbrock Performer Air Gap RPM
Old 05-08-2018, 01:11 AM   #5398
Gregski
Gregski's Avatar
Re: Restoring Rusty
so the one thing I just had to do before starting the re assembly with the new shiny bits was to pull the oil pan and take a looksie, I mean with the heads as milk shaky as they are how in the world can the oil I drain out of the pan be nice and black(ish)
strange I tell ya, strange!
Old 05-08-2018, 01:15 AM   #5399
Gregski
Gregski's Avatar
Re: Restoring Rusty
alright we commence with the re assembly
Step 1. Move the shinny bits from the living room to the garage, place them on the work bench and allow them to acclimate to their new habitat (think goldfish in a plastic bag)
Old 05-08-2018, 01:19 AM   #5400
Gregski
Gregski's Avatar
Re: Restoring Rusty
I swear a Top End Swap (heads, intake, etc.) will run you $150 in gaskets and materials alone... good times (I paused my mental calculator...)
Head gaskets - $52
I didn't have the time to order and wait on the proper Edelbrock gaskets to so went with these Fel Pro 7733 PT-2 instead, (then I spoke to Edelbrock Tech Support and they recommended Fel Pro part # 1003, oh well) the important spec was to match to how tight they smash down to once torqued...
