Old 03-07-2017, 07:39 PM   #1
billnorman
Broken head Pipe Stud
O.K.Kiddies here we go again. I'm still working on the 5.7 motor in my 1992 Surbooban, and the donut on the passenger's side was blown out. I removed two of the three studs CAREFULLY but the third one went *Ping* and snapped off. I'm not going to waste my time laying on the ground with metal chips falling in my face if I don't have to. Has anyone tried the AP8001 repair gadget? I'm gonna try but I'd rather hear from someone else that has been successful before I order some.
How about the Nickson 17351 Clamp-A-Stud 1 1/4-2 3/4 has anyone tried these?
billnorman is offline   Reply With Quote
Old 03-08-2017, 10:23 PM   #2
JJR
JJR's Avatar
Re: Broken head Pipe Stud
I've had friends use the Nickson style clamp and it worked for them. I busted a stud on the passenger side manifold when I had to replace the y-pipe in the 93 Sierra I had. I just went ahead and pulled the manifold so it could be heated up with a torch so the busted stud could be removed.
FOUNDING MEMBER OF THE DRUM BRAKE CLUB
Second Owner 70 C-10
Second Owner 93 GMC C1500
Third Owner 99 C2500 Crew Cab Short Bed
JJR is offline   Reply With Quote
Old 03-11-2017, 03:15 PM   #3
diveplane
thing i have found out on old trucks is pre soak any old bolts with pb blaster for a day or so before starting any bolt removal process.
learned my lesson with front shocks,
also a high impact wrench gets the job done as well,
electric units every bit as good as the air type if u dont have access to air supply.
diveplane is offline   Reply With Quote
Old 03-18-2017, 07:16 AM   #4
billnorman
I didn't have an impact wrench where I was working at the time. I did buy a gizmo that fits over the manifold and a stud drops down into the head pipe, which I have yet to install, but I did get a donut gasket in the pipe and two studs tightened, and got it to my house with less noise. The P.O. has sawed the factory muffler off and put in a straight pipe, it's not real noisy it has that huge catalytic cnoverter on it.
