07-21-2020, 09:08 PM | #1 |
Some parts from around the core support
Upper radiator mount, both side baffles, the metal piece for the seal in front of the radiator, and the hood spike piece.
The radiator mount and hood spike are both in great shape. One of the side baffles is in useable shape, but the other one needs some work. I'm not sure if the bent up one could be saved. The metal piece for the seal on the top front of the radiator is also bent up a little, but since it is a flat piece of metal, it could probably be straightened up pretty easily. Upper mount SOLD Hood spike piece is $20 shipped. I'll do $30 shipped on the radiator seal parts since they have to go in a bigger box. I also have the voltage regulator and horn relay. The horn relay has Delco-Remy stamped in it. Untested, but $15 shipped if you want to take a gamble on them. Last thing is the horn. It is damaged, and I haven't tested it yet, but if you are interested in it, let me know so I can test it. If it works, it's yours for the cost of shipping. Come pick up the parts and save on shipping if you're close by! Thanks for looking!
Christian Carpenter 1963 C10 - Frankentruck 283, 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson Last edited by cwcarpenter98; 07-23-2020 at 10:43 AM. Reason: Sold some pieces |
07-21-2020, 11:11 PM | #2 |
Re: Some parts from around the core support
Christian...if the horns work I will take them for the cost of shipping. PM or text me. No rush. Thanks!
07-22-2020, 09:03 AM | #3 |
Not sure if Roll the dice bought everything or just the horn. i only need the radiator clamp/hold down. If it gets to me i need a price shipped to 95012. thank you
07-22-2020, 09:24 AM | #4 |
Hey Andy, it's just the one horn. I'll test it later today and let you know
Christian Carpenter 1963 C10 - Frankentruck 283, 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
07-22-2020, 09:25 AM | #5 |
You are just wanting the upper radiator hold down piece? How does $35 shipped sound?
Christian Carpenter 1963 C10 - Frankentruck 283, 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson Last edited by cwcarpenter98; 07-22-2020 at 09:33 AM. |
07-22-2020, 09:58 AM | #6 |
07-22-2020, 01:03 PM | #7 |
PM sent with payment options
07-23-2020, 01:44 AM | #8 |
07-23-2020, 10:40 AM | #9 |
Payment received, thanks!
Please send me your address so I can get it shipped to you.
07-23-2020, 06:20 PM | #10 | |
Anyone know another option to make it work again?
08-01-2020, 12:36 AM | #11 |
Hey TChevs, my apologies, I haven't sent the mount out to you yet. I have it boxed up, and I'll send it out tomorrow. Thanks!
08-01-2020, 06:09 PM | #12 |
08-05-2020, 09:29 PM | #13 |
Received the radiator strap. Thank you
08-06-2020, 09:57 AM | #14 |
Thanks for letting me know!
