08-09-2020, 02:20 PM | #1 |
Hot restart
Twice now after sitting for 10-15 minutes I restarted and the engine just falls on its face. Similar to it its real cold and not warmed up. 90+ air temp, was running A/C prior to shutoff both times. GM 350/357 performance crate motor, Holley 670 CFM carb. Running a mech fuel pump. After a couple of minutes it is OK. Next time I restart after 10-15 min it is OK. Ideas?
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
08-09-2020, 03:20 PM | #2 |
Re: Hot restart
Carb getting heat soaked?
Are you running ethanol gas? Ethanol can boil at some really low temps. Even non ethanol gas can boil in a hot engine compartment, just not at as low temps. You might try a phenolic spacer to insulate the carb. Also, does your fuel line have a return, or does it just "deadhead" at the carb? Your fuel might be vapor locking between the pump and the carb. Timing set a little to advanced could cause hot start problems also. Do you know what your timing is set at?
Insert clever text here: Last edited by Greasey Harley; 08-09-2020 at 03:29 PM. |
08-09-2020, 07:49 PM | #3 | |
Re: Hot restart
California stuff. What is weird is it is not repeatable. Last week I made a bunch of short trips running errands and it only did it once. Starts right up, just when accelerating pretty much nothing. That's what has me stumped.
08-10-2020, 03:04 PM | #4 |
Moderator
Re: Hot restart
How old is your carburetor?
08-10-2020, 04:39 PM | #5 |
Re: Hot restart
New this Feb, it came with the new GM crate motor. Then had it chassis dyno tuned.
I'm wondering if what I experienced is a combination of high underhood heat and the open air cleaner sucking in the hot air. Didn't backfire just stumbled with no power.
08-10-2020, 04:56 PM | #6 |
Re: Hot restart
Use a heat shield like this.
Keeps the bowls cooler. https://www.holley.com/products/fuel...s/parts/108-70 |
08-11-2020, 03:31 PM | #7 |
Re: Hot restart
I have the same problem. If I drive long enough to get the good and hot, not overheated but a short drive won't do it, then I shut it off for 20 or 30 minutes it will crank as if flooded. If I crank it right back up after shutting it off it won't do it. If I wait until the motor cools down it won't do it.
I have a L31-R crate motor with a Holley carb and electric fuel pump. I have given up on it but I believe it may have something to do with the electric choke closing and the motor still being warm/hot. |
08-12-2020, 03:14 PM | #8 | |
Re: Hot restart
08-12-2020, 09:50 PM | #9 | |
Re: Hot restart
Any other style is never close enough to what you need. |
08-14-2020, 06:09 PM | #10 | |
Re: Hot restart
