Old 07-17-2020, 10:12 AM   #1
Scott2
Stp?
Thought about STP Oil Treatment this morning for no reason - who still uses this stuff?
About a hundred years ago when I was younger I used it for all the cars I had with crappy rings and loose everything in the motors, used in a few times for assembly lube, and sometimes just cause I listened to the ads.
My worst offense with it - although pretty clever I thought at the time - was when I was buying, selling, and swapping cars a lot. I traded for a '64 Dodge hippie van with a straight 6 that turned out to get about 4 miles to a quart of oil. I was commuting to Cal State Long Beach for college and could barely get to class without taking a case of oil with me!
I switched to 4-1/2 quarts of STP and 1/2 quart of oil! That got rid of the giant cloud of smoke out the back (but not the one coming out of the inside of the van with a bunch of classic rock pouring out of the 8 track and giant box speakers) and held it together long enough for me to trade it to a guy for a '66 Nova.
Just curious if there's a good use anymore? It is sticky and slippery as hell so why not?
Scott
______________
my '51 build: http://67-72chevytrucks.com/vboard/s...d.php?t=677979
Scott2 is offline   Reply With Quote
Old 07-17-2020, 05:29 PM   #2
Custom 68
Custom 68's Avatar
Re: Stp?
I tried some recently on some noisy ls lifters, it didn't help so I ended up swapping them out anyway. But well worth a try.
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 07-17-2020, 05:39 PM   #3
Getter-Done
Getter-Done's Avatar
Re: Stp?
My personal opinion.
I firmly believed in it 30 years ago.
I think it is been changed from what it used to be (Maybe just me).
Not trying to start any debate or endorse any product here.
I use Lucas Oil Treatment in it's place now.
I drove a truck 2 years with a rod knocking.
It would use 3 quarts of oil in a month.
I would add STP rod still knocked.
Added Lucas and it would stop knocking.
Just my experience
84 Chevy K-20
Old 07-17-2020, 08:14 PM   #4
Tom
driving is in my blood
Tom's Avatar
Re: Stp?
I've never been into the gimmicks. That being said: Had a porsche 911 with a lifter tick and check engine light. The variable cam thing with them is a lifter with a rod in the middle that sticks up to activate the 2nd lobe on the cam, like VTEC on hondas. So our shop says its the lifters, need to replace at like $2000. A another porsche shop tells us to try some hydro lifter additive from liquid moly, then run the piss out of it. I'll be dammed if on day 2 it stopped having any issues, reset the emissions components and went threw emissions fine. That was almost a year ago and as far as I know the car is still good to go.
Old 07-17-2020, 10:48 PM   #5
'68OrangeSunshine
'68OrangeSunshine's Avatar
Re: Stp?
When I rebuilt a 292 in 1977, my buddies were down on ever using it, as they considered that the additives just gunk up your engine and make cleaning it for rebuilding that much harder.
Until a few years ago, when I was concerned about the level of ZDDP in common motor oil, I started using STP for the zinc. When I found out Valvoline Racing had the right amounts of ZDDP, I went to VR1 SAE 30 exclusively.
Old 07-18-2020, 03:05 AM   #6
BigRandy
BigRandy's Avatar
Re: Stp?
I used it in the late 70's because I wanted to believe the hype. Never could tell that it made a bit of difference and would rate it about a notch above mashed banana peels. Still not sure what it actually does other than raise the viscosity, but here's a link to a guy who tests all sorts of products in his garage. He did an old Vs new STP test about a week ago. Wouldn't want it anywhere near a motor in cold weather.
https://www.youtube.com/watch?v=mqiUFklL_XI
Repairing and driving old trucks is an analog experience. No computers or sensors and they can be fixed with basic hand tools
BigRandy is offline   Reply With Quote
Old 07-19-2020, 12:32 AM   #7
vince1
Re: Stp?
I heard of a kid who got a job at a local garage. He was asked to add in a can of stp and where did he put it but in the radiator. I guess they had quite a time cleaning it out.
vince1 is offline   Reply With Quote
Old 07-22-2020, 11:05 PM   #8
toolboxchev
Re: Stp?
I have seen it work with a well worn engine. Same with Lucas. Beware though if there are not anti foaming agents in this stuff you will have other problems.
Regular Oil has anti foaming agents to prevent the oil pump from sucking foam.
toolboxchev is offline   Reply With Quote
Old 07-23-2020, 03:23 PM   #9
truckster
truckster's Avatar
Re: Stp?
I know there used to be a product called Motor Honey that was a similar thickener. The idea is to make the oil thick enough that it doesn't go past the rings or valve seals, but I've always thought that if oil is too thick to go past rings and seals, it's probably also too thick to go to places it needs to go.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 07-23-2020, 04:54 PM   #10
LS short box
Re: Stp?
I kind of like the products that fill in the scoring in the cylinders!
LS short box is offline   Reply With Quote
Old 07-24-2020, 12:48 AM   #11
toolboxchev
Re: Stp?
I tried that ProLong stuff before I rebuild the top end of the motor. I can say this it has not hurt anything.
Old 07-30-2020, 01:07 PM   #12
mattfranklin
mattfranklin's Avatar
Re: Stp?
40 years ago I used it to quiet down the rockers on a '66 Ford F100 with the I-240.
It worked for a short time. Now I understand that the viscosity additive was just shearing down.
Also, all of the race cars that advertised it, if they were honest at all, were probably just using it for assembly lube. And now there are better moly assembly lubes anyway.
Make your engine healthy first, if only with a simple de-ridge and ball hone and new rings and bearings. Then do regular oil changes. That's your best bet.
Still, an STP sticker on your car makes it go faster. Everyone knows that. ;-)
(Very) Slow-Going Build Thread: Stock 1970 Short Step with Stock 1970 LT-1
http://67-72chevytrucks.com/vboard/s...d.php?t=567340
mattfranklin is offline   Reply With Quote
Old 07-30-2020, 10:24 PM   #13
Getter-Done
Re: Stp?
I could not have said that better
84 Chevy K-20
Old 07-31-2020, 12:35 PM   #14
truckster
truckster's Avatar
Re: Stp?
And lets you drive like Richard Petty...
Old 08-02-2020, 11:11 AM   #15
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
Re: Stp?
The STP in the blue cans is a good "cheap" source for zinc! I used it (and still do) for years in my 4-stroke Z1 racing motors. It's great stuff for flat tappet motors, the downside of STP oil additive is the "thickening" agent used in it a cellulose paraffin matrix that has tendency to gather or bind together in slack areas such as the top of the heads and corners of the crank case. A racing motor that gets opened up and cleaned regularly it posses no problem. But in daily drivers that run for years of hot and cold running intervals it will collect and cause sludge. Ever pop a valve cover off to find 2" inches of black tar build up around the moving parts? It will clog an oil filter and cause the bypass to open allowing the build up on the heads as well as slack areas in the crank case. Regular oil changes are a must if you use the stuff and before the oil change a can of SeaFoam or Rislone oil additive added to the crank case a few miles before draining the oil helped clean that sludge out...Zinc phosphate (ZDDP) only works when it gets to the moving parts while suspended in the oil...
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 08-02-2020, 06:50 PM   #16
'68OrangeSunshine
Re: Stp?
I used a quart of Shell X-100 Oil Stabilizer along with 5 quarts of Valvoline VR1 SAE 30 on my most recent oil change on the 292. [292 is a 6 qt system with a long oil filter.] I usually try for 2500 mile intervals, but I had neglected it and gone almost 5000. Also I used a Wix 51061 oil filter -- the anti-drainback kind. Since the oil filter is high on the right side of the L6, and can drain back. On the V8 I use the 51060, since the oil filter is on the bottom of an SBC anyway.
With the X-100 the engine is a lot smoother and quieter on the freeway.
Thread Tools
Display Modes
