09-21-2022, 07:33 PM | #1 |
Frame swap question.
I am trying to figure out if a 67-72 truck body will fit on any other year frames.
I purchased a 72 basket case k20. Not real happy with the condition of the frame. Will a 73-to 87 frame fit? I have tried to find info but only found a couple threads and they say the early body won't fit correctly on the newer frame. Any help would be greatly appreciated. |
09-21-2022, 07:43 PM | #2 |
Re: Frame swap question.
https://youtu.be/dahVzNjZoHQ
There are differences from front to back. It can be done. This guy has a good video of a side by side comparison.
:My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=807535 1971 c10 swb/1972 K10 swb/1968 Camaro 350/4spd 1955 210 2 dr sedan/1998 RCSB Z71 |
09-21-2022, 08:15 PM | #3 |
Thank you.
That pretty much answers my question. It's not going to work for me. |
09-21-2022, 09:22 PM | #4 |
I have a customer that put his on a Tahoe frame
09-22-2022, 12:22 AM | #5 |
That had to be a lot of fab work. But worth it I bet.
09-22-2022, 02:25 PM | #6 |
Tahoe chassis for me, but it is a lot of fabrication.
with stock setup they sit kinda high (like4x4), going to add drop spindles. |
09-22-2022, 02:44 PM | #7 |
All about them K’s
If you are going to keep it 4x4 don’t put it on a Tahoe frame, keep the front solid axle. That’s my personal opinion. It can be made to work with a square body frame but it will require an inch or so body lift to get everything sitting level. Also the squares have a little longer wheel base.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
