06-06-2017, 01:04 PM | #26 |
Re: Dumptruck Dolly
Woah, those 19.5's are a must for any dump truck now that I've seen them, holy cow those are awesome on these little trucks. The door logo is pretty awesome, looking forward to this build, subbed
Project NewType 1972 Chevy C/10 Cheyenne Super ( Daily Driven Showtruck ) http://67-72chevytrucks.com/vboard/s...d.php?t=507903 Project Great Grandpa's Legacy 1973 Chevy C/10 Cheyenne ( Current daily driver collecting big time parts ) http://67-72chevytrucks.com/vboard/s...89#post7084289 - Dylan (209)-985-7721 |
06-07-2017, 02:58 PM | #27 |
Re: Dumptruck Dolly
bigrigpardo's 19.5" wheels look great...I need to find 2 more 17.5 inch tires for the front yet...and I am looking forward to getting the dump bed set, hopefully soon.
06-07-2017, 03:03 PM | #28 |
Re: Dumptruck Dolly
I have never looked at the V6 up close...Cool. I have a Eaton HO72? with crazy gears as well, but its in the back yard under a tarp. I did seem to get the last set of brand new drums off of a shelf in Seattle...probably 15 years ago. Those are hard to come by.
06-07-2017, 05:06 PM | #29 |
Re: Dumptruck Dolly
06-09-2017, 09:38 PM | #30 |
Re: Dumptruck Dolly
Found my silver bumper, 3 dents and a couple of edges bent...no problem.
06-09-2017, 09:41 PM | #31 |
Re: Dumptruck Dolly
Another view
06-09-2017, 09:44 PM | #32 |
Re: Dumptruck Dolly
An unsightly carriage bolt opening that needs repair.
06-09-2017, 09:47 PM | #33 |
Re: Dumptruck Dolly
Using the scrap bumper for the filler.
06-09-2017, 09:50 PM | #34 |
Re: Dumptruck Dolly
welded up, and used flap disc to smooth it out.
06-09-2017, 09:53 PM | #35 |
Re: Dumptruck Dolly
Pounded out the dents, straightened the edges and put a skim coat of filler prior to primer.
06-09-2017, 09:54 PM | #36 |
Re: Dumptruck Dolly
Primered and done for tonight.
06-11-2017, 01:37 PM | #37 |
Re: Dumptruck Dolly
Great work on the repairs.
06-12-2017, 12:53 AM | #38 |
Re: Dumptruck Dolly
Thank you...onto paint and putting it back on.
After getting it back in place, my son says that the other white trim pieces look out of place...I'll take care of that tomorrow. |
06-12-2017, 11:05 AM | #39 |
Re: Dumptruck Dolly
I am pretty happy that Dolly got a facelift of sorts.
06-17-2017, 06:58 PM | #40 |
Re: Dumptruck Dolly
Busted and rusted side mirrors have to go.
06-17-2017, 07:06 PM | #41 |
Re: Dumptruck Dolly
Found nice replacements at Champion for about $9 each. Dolly is not much for a lot of shiny parts, so I scuffed up the chrome, and shot some white on them, like the originals were.
06-17-2017, 07:17 PM | #42 |
Re: Dumptruck Dolly
I am going to put "dirt" tires on the rear wheels, as this is 2 wheel drive...the street tires may struggle up and down my hills...I found wheels and cleaned them up. I'll have to wait for good weather to get the epoxy primer on them.
06-17-2017, 09:01 PM | #43 |
Re: Dumptruck Dolly
Here are the tires going on the back. I'll run the street tires in front.
06-30-2017, 04:37 PM | #44 |
Re: Dumptruck Dolly
Wow! The weather has just been terrible! Rain for days on end. Finally found a day to get the painting accomplished on the wheels. Monday, I get the new tires mounted.
06-30-2017, 04:42 PM | #45 |
Re: Dumptruck Dolly
Check out this rusty crossmember holding up the carrier bearing. That will have to be taken care of next. Notice the lack of exhaust pipe. A new exhaust is on the way, and should arrive about July 19th.
06-30-2017, 05:10 PM | #46 |
Re: Dumptruck Dolly
Only crossmember that I have is from a half ton truck. Notice the width dimension of approximately 37.25 inches. The 1 ton is approximately 34 inches as the leaf springs are on the outside of the frame. The height is the same, but I will have to come up with some elevation for mounting the carrier bearing. It is what I have, and I will fabricate this to work and hopefully not look hokey.
07-01-2017, 08:03 PM | #47 |
Re: Dumptruck Dolly
Inside width of Dolly's frame is 33.25". I made a "Z" cut in the half ton crossmember similar to chopping a frame to make a shortbox. I figured it would add strength.
07-01-2017, 11:25 PM | #48 |
Re: Dumptruck Dolly
Welded up the crossmember and shot some primer until I get at it again. There are upper brackets I have to come up with if I want it to look stock. Not sure what I'll do.
07-01-2017, 11:34 PM | #49 |
Re: Dumptruck Dolly
I got distracted trying to finish up the dual exhaust on the car hauler. You'll see some exhaust pipe examples on the back of the rolloff that I got from my local parts store. If you look closer, you'll also see MORE projects at different stages...I count 4. Also, more rain! I think I will sandblast the crossmember when it clears...
07-02-2017, 08:01 AM | #50 |
Re: Dumptruck Dolly
Missed this thread. Super cool truck
