09-12-2017, 04:31 PM | #1 |
straight 6 intake exhaust clamp?
Im missing an exhaust /intake bolt with this piece on it that holds intake and exhaust manifold to the head. cant find it anywhere. It came off a 1968 c10 4.1l 250
09-12-2017, 04:42 PM | #2 |
Re: straight 6 intake exhaust clamp?
If you cannot find any, one can be made from a piece of 1/2" thick bar stock. Max torque on those is only 30 lb-ft. Have done it more than once.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed. |
09-12-2017, 04:44 PM | #3 |
09-12-2017, 04:48 PM | #4 |
Does anyone know what it called?
09-12-2017, 06:29 PM | #5 |
Do you have all the clamps except one long style? below are a couple of old threads about the clamps. I wouldn't bother replacing any of the missing bolts. NAPA should have studs that fit for a much easier installation. There should be two studs now in the 3rd hole, in from each end. Head rebuilders often remove them and don't replace.
http://67-72chevytrucks.com/vboard/s...d.php?t=374618 http://67-72chevytrucks.com/vboard/s...d.php?t=454785
'67 GMC 2500, 292, 4spd, AC |
09-12-2017, 07:21 PM | #6 |
09-13-2017, 01:32 AM | #7 |
Thanks to all I'm fabbing some 1/2 inch. Figured I could test my skills
09-16-2017, 05:17 AM | #8 |
thanks for the help guys get her fixed up and sounding normal again !
09-17-2017, 03:45 PM | #9 |
Maybe use an old chevy rocker arm flipped backward?
09-17-2017, 08:02 PM | #10 |
I have used the high-grade alloy steel pivot ball -- flipped around -- to secure the end bolts on L6 headers. Studs hold the stock manifold in that set up.
