09-19-2018, 09:46 PM | #1 |
Which drive train options denote HO52 vs Dana60?
Both of these show up in three-quarter tons for all years. How did the factory spec Dana 60 vs HO52?? GVW? Small Block- Big Block? Auto or Stick? None of the above??
Thanks, Steve weim55 Colorado |
09-19-2018, 10:15 PM | #2 |
Re: Which drive train options denote HO52 vs Dana60?
I too would like to know!
68' with no bells or whistles unless I add'em. |
09-19-2018, 11:20 PM | #3 |
On C/20s you got the Dana 60 with the leaf spring option and the big block/auto combination. All C2500s came with Dana60
09-20-2018, 04:50 AM | #4 |
curious question, does the spid indicate an difference between the dana and the ho? not through the leaf vs coil option but separately as a separate item.
09-20-2018, 05:53 AM | #5 |
No. Neither are an option themselves. GMC went with Dana60 rear and Chevy stayed with the corporate rear. I guess for economics, since GMCs came through with leaf springs, GM used the same rear when Chevys got the leaf spring option. GM wanted a taller gear ratio for the big block coupled with automatic transmission than offered in the corporate rear, so they went with the Dana60 with 3.54 ratio. The 3.54 ration also does not show as an option, but was what you got when you went with BBC/auto options together.
09-20-2018, 06:20 AM | #6 |
Were there Dana's in the 3/4 tons 4x4's? They would not big block available but had leaf springs. All the ones I have seen have the Eaton.
09-20-2018, 07:34 AM | #7 |
I had a 69 GMC k2500 with the Dana 60. Didn't all 3/4 4x4 chevs get the HO's?
09-20-2018, 07:49 AM | #8 |
My 69 c20 is a factory 396, th400 with a 3.54 dana 60. But also has a coil rear end.
I thought it went small block = ho52, big block = dana 60.
John 69 c20, 396, th400, dana60, ps, ac |
09-20-2018, 08:30 AM | #9 |
Big block Chevy with 4spd got the HO52. Big block/auto Chevy got 3.54 Dana60. Leaf Spring was still an option, so both coil and leaf were offered. K2500s came with Dana60 and K/20 came with HO52.
09-20-2018, 09:29 AM | #10 |
Proprietor of Dale's Corner
My parets truck is a 71 C20 350, 4spd, leaf springs. It has a dana 60 with 4:10 ratio. The 350 is also the "Corvette " option......
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man Last edited by Ol Blue K20; 09-20-2018 at 09:32 AM. Reason: Add text |
09-20-2018, 11:29 AM | #11 |
My 70 C20 was a 350/th350 leaf springs with the Dana 60 and 4.10
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
09-20-2018, 11:36 AM | #12 |
My 69 C20 Longhorn has the Eaton HO52. 350 4 speed.
Grandpa 1953 M38A1 Jeep 1989 GMC K2500 1958 Alaskan Camper all original WORK : A necessary evil that finances what I really like to do. |
09-20-2018, 06:23 PM | #13 |
Saw a C/20 once, unsure of the year, think it had a Big Block, Dana 60 with coils.
Friend has a '70 C/20, 350, Dana 60 with leafs.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90. |
09-20-2018, 07:00 PM | #14 |
subscribed, thanks for the details special-K!
I started out with nothing - and I still have most of it |
09-20-2018, 08:08 PM | #15 |
Who Changed This?
Mine's a C20, 400/400 w/ 3.54 Dana 60 and leaf springs. A commoner, I guess.
09-21-2018, 11:14 AM | #16 |
Something I noticed from another thread the HO52 is a 5200lb axle and Dana 60 is a 5500lb axle, All Camper Specials get the 5500lb. Dana? Coil spring Dana produced? And lastly, no 3.54 for the HO52?
09-21-2018, 11:50 AM | #17 |
Those ratings mean nothing to me. The HO52 was rated in the '40s when they first were used. The fact is the HO52 is stronger. At least that is my opinion/experience. What's 300# anyway, a passenger?
Yes there were coil spring Dana 60s. No 3.54 HO52s. 4.10 was the tallest gear offered. There was an aftermarket gear set in 3.90 offered at one time. Big whoop, not even a quarter turn gain for that expense and labor. Taller tires could make more sense.
