Old 02-23-2014, 09:22 PM   #76
oldman3
oldman3's Avatar
Re: 1950 3100 Full Custom **GunMetal**
Looks good with the cab and running boards on....Jim
oldman3 is offline   Reply With Quote
Old 02-23-2014, 10:38 PM   #77
vince921
Thanks hope to have the front end all together in the next week or so
vince921 is offline   Reply With Quote
Old 02-23-2014, 11:03 PM   #78
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Looks amazing, great work man.
--Josh
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218
A good crossthread is better than Loctite any day.
Life is not about what you have, but who you have to share it with.
STOCKISH is offline   Reply With Quote
Old 02-23-2014, 11:21 PM   #79
50adrod
50adrod's Avatar
looking good, remember to plumb in a water trap before the accuair valve. looking forward to your updates
1971 Corvette convertible 454@ 525 hp
1936 Chevy Truck street rod
1952 Chevy truck hot rod build http://www.killbillet.com/showthread...2-Chevy-Cut-up
1964 F 100 custom street rod http://www.ford-trucks.com/forums/12...mark-viii.html
1950 custom Chevy Truck
50adrod is offline   Reply With Quote
Old 02-23-2014, 11:37 PM   #80
vince921
Thank you sir ! Yeap plan on putting the trap right right off the tank
Old 02-24-2014, 08:59 PM   #81
vince921
finally got the accuair in today..... and got to pound away on it for a few hours got most of the wiring ran .... need to get some compress lines made... and still debating if i want to go with the copper line kinda weighing my options at this point..
pretty happy with how i was able to hide most of the wiring.! The accuair setup is top notch ... unbelievable technology.
Old 02-24-2014, 09:01 PM   #82
vince921
i havent gotten this far in the instructions but when you installed your accuair i assume you get everything plumbed and wired and working with the accuair controller and then continue on to installing the sensors???
Old 02-24-2014, 09:41 PM   #83
focusedontheprize
focusedontheprize's Avatar
Truck is looking great Vince.
focusedontheprize is offline   Reply With Quote
Old 02-24-2014, 10:31 PM   #84
vince921
Thank you sir
Old 02-25-2014, 12:00 AM   #85
50adrod
50adrod's Avatar
I don't think the sequence matters but I installed my sensors first because I was working on the shock mounts in the same area, I knew you would be impressed with the quality, I was
Old 02-25-2014, 07:24 AM   #86
vince921
Okay got it and you had no problems keeping it in the 2.75 travel range ?
Old 02-26-2014, 09:42 PM   #87
vince921
welp i decided last minute to do what i really wanted to do deep down inside... so i went copper!! and it came out great everything is plumbed ! accuair is wired and working all i need to do now is mount my sensors and calibrate and the air ride will be complete!!!!
more pictures are on the way!
Old 02-26-2014, 09:51 PM   #88
*Kenny
looks so awesome!
*Kenny is offline   Reply With Quote
Old 02-26-2014, 10:04 PM   #89
vince921
Have a little touching up to do and maybe some kind of grommet worked out well went through the frame
Old 02-26-2014, 10:16 PM   #90
CMFT
CMFT's Avatar
Wow, that looks incredible! Well done.
'58 Apache
CMFT is offline   Reply With Quote
Old 02-26-2014, 10:22 PM   #91
vince921
Thank you sir
Old 02-26-2014, 10:56 PM   #92
99 to Life
99 to Life's Avatar
looks stellar man, so your just running plastic up the front? I like how the compressor is farther from the tank, let that air cool down before filling the tank. really dig that accuair set up. Thought about that the route and may even go there.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 02-26-2014, 11:04 PM   #93
vince921
Yes I took the cooper to the outside of the frame rail and then switched it over with a union fitting ... Worked out well and no leaks ( knock on wood )
As far as the Accuair it's amazing I won't do another vehicle without it. If only they could have a little faster shipping it would be stellar but its well worth the wait.
The compressors worked out well and luckily I have a great guy right down the street the does any kind of line fittings I could ever want
Old 02-26-2014, 11:42 PM   #94
oldman3
oldman3's Avatar
Super nice job, looks great...Jim
Old 02-27-2014, 01:15 AM   #95
Flames97
Flames97's Avatar
Very nice.
-Aaron
'15.5 Chevy Duramax LTZ/Z71, LML, CC/SB
'77 Chevy K10, 4" lift, 33-12.50, 350/350
'55 Chevy Short Box (In Pieces)MII,4-link,Bagged,383 Stroker,700r4,3.73posi (SOLD)
My 55.2 Chevy 3100 Build
Flames97 is offline   Reply With Quote
Old 02-27-2014, 07:05 AM   #96
vince921
Thanks fellas hope to get the sensors installed tonight !
Old 02-27-2014, 10:21 AM   #97
youngrodder
youngrodder's Avatar
Looks great. I love the contrasting color of the copper next to the gray frame paint. I imagine Copper is pretty easy to work with. The only draw back would be the cost. Are those both fair assesments?
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 02-27-2014, 10:28 AM   #98
vince921
The copper was very easy to work with ...after I got it straightened out. With a good tubing bender it's pretty straight forward
And as far as cost I probably only spent about 60 bucks on 50 foot and ended up with about 15 foot left ( I used a bit to practice on )
Old 02-27-2014, 11:38 AM   #99
youngrodder
Good to know. How did you go about straighting it?
Marc
Old 02-27-2014, 11:50 AM   #100
vince921
Cut my pieces to the lengths I needed and then layd it out on the bench and took a 18 inch 2-4 and rolled it ... Comes out straight as an arrow
