Old 05-15-2020, 09:30 PM   #1
Chvy2NV
Squaring up and aligning PB Frame ?
hey guys, im currently putting my PB parts together, all has been pretty smooth so far, the guys at Porterbuilt are amazing to work with.
I need help on how to make sure the frame comes back together squared and aligned
Chvy2NV is offline   Reply With Quote
Old 05-16-2020, 03:13 PM   #2
SCOTI
SCOTI's Avatar
Re: Squaring up and aligning PB Frame ?
My 64's set-up is PF front x-member, LWB-to-SWB frame chop, & rear frame 'Z'. Not exactly apple-to-apples but in the same spirit...
I did diagonal measurements based off of factory holes on each rail/side. I did diagonal measurements from:
Front rail ends to rear rail ends
Front rail ends to back cab mounts
From back cab mounts to rear rail ends
The frames weren't perfect from the manufacturer (mine was off <1/8" when measured as a LWB). I was able to get within 1/16" diagonally once modified.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-16-2020, 08:29 PM   #3
Chvy2NV
Scoti when taking these measurements. Was the truck on the ground as a roller or can it be done on jack stands ?
Old 05-16-2020, 08:44 PM   #4
SCOTI
SCOTI's Avatar
It was on jack stands. I assembled the main pieces into place w/the hardware lightly snugged. I wanted things secure but still movable. I then started the measuring & used ratchet straps to pull things for squaring it up. Once I liked the numbers, I tightened everything up.
My hardware was all yellow zinc plated. I tagged each bolt w/a Sharpie as they were torqued down once it was squared. This allowed me to go back & double check what was torqued & what was just temporarily secured.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-17-2020, 12:45 AM   #5
Chvy2NV
You did this during final assembly I’m assuming. Not for mock up ?
Old 05-17-2020, 01:40 AM   #6
SCOTI
SCOTI's Avatar
Tagging the torqued-to-spec hardware? Final assembly only.
Loosely assembling & squaring the chassis? It was done for both mock-up & final assembly. Eliminate surprises when possible.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-19-2020, 02:40 PM   #7
Chvy2NV
Thanks brother
