Old 12-26-2017, 10:58 PM   #1
Robznob11
Robznob11's Avatar
Need a drop spindle recomedation
Ok guys I have western 2.5 71-72 drop spindles currently. I have pb fab forward and narrowed arms with bags. Problem is That I run 15" wheels and would like to install heims on the bottom side of tie rod mount to clear up bumpsteer. I dont think it will clear the tire and rim. Are there any drop spindles on the market that move the tierod mount inboard some? I have heard beltech does. I would not have a problem with a 2" drop insted of 2.5 for wheel clearance.
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 12-27-2017, 03:58 PM   #2
SCOTI
SCOTI's Avatar
Re: Need a drop spindle recomedation
Looking @ the pic.... The TRE looks to be pretty close level wise as the lower a-arms (pivot point to BJ). Moving the TRE to the bottom of the spindle steering arm would have them much different vs where they are now & would not help a bump-steer issue. It would make it worse.
You want them as close as possible level/angle wise.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 12-27-2017, 04:44 PM   #3
Robznob11
Robznob11's Avatar
I think the angle of the pic may be misleading
LED TAILS
Old 12-27-2017, 05:00 PM   #4
SCOTI
SCOTI's Avatar
Yep, the pic was mis-leading.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-27-2017, 05:03 PM   #5
Robznob11
Robznob11's Avatar
Lol, i was zooming in on the potential clearance issue and where i was hoping to find a spindle that is pulled in a bit🤣
LED TAILS
Old 12-27-2017, 05:15 PM   #6
SCOTI
SCOTI's Avatar
Lol, i was zooming in on the potential clearance issue and where i was hoping to find a spindle that is pulled in a bit��
Would there be enough room if the TRE was flipped or would that be an interference issue as well?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-27-2017, 05:37 PM   #7
Robznob11
Robznob11's Avatar
Wink Re: Need a drop spindle recomedation
I ordered more custom sleeves, heims and misalignment bushings today. Gonna try it out. Total width is 1.83. We shall see
LED TAILS
Old 01-03-2018, 03:35 PM   #8
gringoloco
A guy with a truck
gringoloco's Avatar
Where did you get your taper sleeves?
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 01-03-2018, 03:37 PM   #9
Robznob11
Robznob11's Avatar
Got it all from rod end supply!
LED TAILS
