Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 04-16-2019, 10:35 AM   #1
MikeB
MikeB's Avatar
Dash lamps for 69 truck
Would like to hear your suggestions for dash lamps. RockAuto shows the following, among several others:
Wagner #1445 -- 1.94 watts
Wagner #1816 -- 4.29 watts
They also list LL (long life) versions of the above with the same wattage specs.
Obvious I'd want the higher wattage bulbs, but are those specs correct?
FYI, AC-Delco has a L1445, but they don't show wattage.
Also, I want to get a few bulb sockets. Will I need both 1/2" and 5/8"?
The truck is at my son's house 1500 miles away, so I can't pull the instrument panel to check it.
Mike
82 C10 Custom Deluxe SWB -- original paint, 355/TH350, Vortec heads, GM RamJet 350 roller cam
69 C10 LWB -- Bought in 1989, now my son's http://67-72chevytrucks.com/vboard/s...d.php?t=775449
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 19 years! This is the very first car/truck Internet forum I joined.
MikeB is offline   Reply With Quote
Old 04-18-2019, 12:57 PM   #2
MikeB
MikeB's Avatar
Re: Dash lamps for 69 truck
Bump
Mike
Old 04-18-2019, 08:09 PM   #3
dmjlambert
dmjlambert's Avatar
The lamps are 194 wedge base lamps. If you like them brighter than standard, a 168 bulb is the brighter version.
Old 04-19-2019, 01:14 PM   #4
MikeB
MikeB's Avatar
Thanks. Same as my 82 truck.
1816 and 1455 must be the latest bulb numbers.
Do you know if the sockets are 1/2" or 5/8" diameter?
Mike
Old 04-19-2019, 06:49 PM   #5
dmjlambert
dmjlambert's Avatar
5/8 according to this listing
https://www.classicindustries.com/pr...ts/cx1807.html
I don't think you can be 100% sure until you walk up to the truck. I have seen mention on this forum about people finding completely different bulb holders and bulbs in their truck's instrument cluster.
Copyright ©2000 - 2019, vBulletin Solutions Inc.
