Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 04-03-2019, 01:49 PM   #1
WorkinLonghorn
WorkinLonghorn's Avatar
GMC Headlights (4 bulbs) all dead or dims only.
I can only run with dims (outboard ones). If I need high beam all are dark. I replaced the dimmer switch with a known good one, no change. What would cause this? Thanks. - Brian
'69 GMC C2500 Custom Camper, 8 1/2' bed (same as Chevy "Longhorn"), 350 ci. mild RV cam, NP 435 CR 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent.
WorkinLonghorn is offline   Reply With Quote
Old 04-04-2019, 11:12 AM   #2
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: GMC Headlights (4 bulbs) all dead or dims only.
The power wire for the headlights is the blue wire at the dimmer switch terminal. It connects to the brown wire for low beams and the light green wire for the high beams.
I would try jumping the blue wire and the lt green wire to see if the high beams come on.
If they don't then you might have a break in the light green wire between the dimmer switch and the left high beam head light. Check the dimmer terminal plug for corrosion.
You may also have relays in the wiring if a previous owner had installed them and the high beam relay may have failed.
It"s also possible that all four high beam elements have burned out. Since your two outside bulbs work on low beam I would rule out bad grounds.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 04-20-2019, 07:39 PM   #3
'68OrangeSunshine
'68OrangeSunshine's Avatar
Check ground leads from frame to radiator bulkhead.
Check each bulb for continuity.
Check voltage to headlight plugs.
Check regulator and alternator output.
Old 04-22-2019, 03:28 PM   #4
michael bustamante
michael bustamante's Avatar
definatly check your grounds at the radiator support
1967custom
michael bustamante is online now   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
