Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 04-03-2019, 02:57 PM   #1
snowball
Is the volt meter repairable?
Hi all,
I noticed the thread on the amp meter and figured I would give it a shot.
Is the volt meter repairable? I know I'm getting voltage on mine. I could read it with my DMM.
Analog meter always reads 9V. I can move it by hand but goes back to 9V
1990 suburban r1500 k 350 2wd
snowball is offline   Reply With Quote
Old 04-04-2019, 12:02 PM   #2
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: Is the volt meter repairable?
Originally Posted by snowball View Post
Hi all,
Typically voltmeters measure system voltage, either battery voltage or charging voltage. Unless you have high resistance at the meter connections, you should be reading battery voltage or alternator charging voltage. If you are having problems with dim lights or no starts, I would suspect that the voltmeter is faulty. If your DVM is reading 12 volts on the battery and 14.5 volts with the engine running, and 9 volts on the vehicle voltmeter, you have a problem with the volt meter. What do you mean you can move it by hand?
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 04-04-2019, 12:16 PM   #3
snowball
Thank you sir. Yes. 12 V on the battery, 14.5 while running and VM reads 9v
I can physically move the needle on the VM and it goes back to 9V. just making sure the gauge is not seized or anything.
Thank you in advance for all your help. I really appreciate it.
Old 04-05-2019, 07:07 PM   #4
63unibody
63unibody's Avatar
Sounds like the resistor might be bad?
63unibody is offline   Reply With Quote
Old 04-08-2019, 06:57 PM   #5
ray_mcavoy
These resistors usually fail open circuit, resulting in the gauge not responding at all. But it's possible that the resistor failed and someone replaced it with an incorrect (higher resistance) one off a different gauge. Or like VetteVet said, there could be some extra resistance in the circuit (due to corrosion, weak connection, etc) that is causing the abnormally low reading.
Another possibility could be that someone removed the needle (maybe to repaint it) and didn't position it correctly when they put it back on. They're just a press fit onto a tiny round shaft.
ray_mcavoy is offline   Reply With Quote
Old 04-16-2019, 05:38 PM   #6
snowball
No. it's not responding at all. points to 10 oclock no matter what I do. Guauge should go down to 12V when acc is on and 14V when running. Never moves.
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
