Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 04-25-2019, 07:18 PM   #1
WannaBe68
Front Parking Lights Now Break Lights
So I put my 69 Suburban in the shop to have the transmission looked at and when I got it back the two front orange parking lights go on when I press the break pedal! They are in sync with the rear break lights...
And - my Suburban will never be at that shop again, so don't ask if I've contacted the shop about this
Thanks in advance!
WannaBe68 is offline   Reply With Quote
Old 04-26-2019, 03:44 AM   #2
Wgesnerjr
Wgesnerjr's Avatar
Re: Front Parking Lights Now Break Lights
what exactly did they touch while looking at the trans? try to retrace their steps to find something out of place.
I once bought a 76 Trans Am with the same problem. turned out that the P.O. had crammed an 1156 bulb in one of the brake light sockets that called for an 1157 bulb. the single stud base contact would jump the brake circuit with the tail light circuit. this made the front parking lights come on with the brakes.
check simple stuff first then look for missing grounds.
Jay Gesner
Atlanta, GA
1985 C10 Long Bed 4X2
LS 5.3, 4L60E
Father/Daughter Project
Wgesnerjr is offline   Reply With Quote
Old 04-29-2019, 01:26 PM   #3
maynardogle
An 1157bulb can fail in a way that causes this problem. If all the bulbs are OK, I would take a close look at the headlight switch... Sounds like a coincidence with the tranny shop work..not likely their fault.
maynardogle is offline   Reply With Quote
Old 04-29-2019, 03:01 PM   #4
WannaBe68
Thanks, but I honestly have no idea what the shop did except pull the trans and sit it in a corner for over two months...then put right back in.
I think I found a guy, in the Houston area, that can work on the wiring in these old suburbans.
Thanks again
Old 04-29-2019, 05:59 PM   #5
First c10
First c10's Avatar
Maybe they have smashed the 4 wires to the rear of the vehicle between the cross member and the frame. Causing them to touch and now its back feeding to the switch and to the parking lights?
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/4.8L-ly4/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
