03-26-2019, 12:30 PM | #1 |
ball joint lbs on pull scale
Hello all,
I am going back over my front end. I get a little "memory steer". When i rebuilt the front end I remember testing how many pounds of force require to rotate the outer c. Everything checked out during the install, but I can not find the specification of how many pounds it should be. Something is a little tight and i want to double check. Thanks, Chris |
03-26-2019, 01:05 PM | #2 |
Re: ball joint lbs on pull scale
25 lbs i think pulling with a fish scale in the tie rod hole.
also verify the u-joint on the axle is not frozen up . jack up front end and turn the wheel . then try and spin the tire . if the joint is frozen or sticking it will be hard to spin the tire.
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
03-28-2019, 06:01 PM | #3 |
Not enough caster will cause that as well.
87 R30 CC Dually, TBI 454, NV4500, zero rust barn find 87 Jeep Grand Wagoneer, 6.5 turbodiesel, 700R4 |
