Old 05-19-2017, 04:52 PM   #1
5spd540
On a 71 c10 step side
How much can you lower it without have major work and it be safe? I don't want to nag it. I was thinking 5-7 drop but don't know much about these trucks. This is my first full size truck.
5spd540 is offline   Reply With Quote
Old 05-19-2017, 07:19 PM   #2
PGSigns
PGSigns's Avatar
Re: On a 71 c10 step side
5/7 is a lot of drop to get started. What are the overall plans? Are you planning disc brakes or other mods? What wheel and tires are you thinking about? If you are thinking disc brakes 2 1/2 spindles and 2 inch springs. Then 4 to 6" springs depending on how much rake you want.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 05-19-2017, 08:15 PM   #3
5spd540
I have front disc and have not decided on wheels yet was thinking of 20x8 fronts and 20x10 or 12 on the rear
Old 05-20-2017, 07:39 AM   #4
zach_carver
zach_carver's Avatar
Most people I know like the 4/6 best. With spindles and springs in the front. 4/6 is a good drop, and still doesn't hang on everything.
1965 C10 LS2/4l70, WHITE, 5/7 DROP
LINK TO SUPER SNOOPY C10 BUILD---> http://67-72chevytrucks.com/vboard/s...d.php?t=689283
1977 C10 SILVERADO HAWAIIAN BLUE, 5/5" DROP, LS6/4L80E
1976 CHEVY K5, 350/350, YUBA GOLD/SADDLE
zach_carver is offline   Reply With Quote
Old 05-20-2017, 07:40 AM   #5
5spd540
I guess I need to see some pics of 4-6 and 5-7 drops so I can see how low it really is
Old 05-20-2017, 08:03 AM   #6
BossHogg69
motor exploder
BossHogg69's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=471442
30-odd pages of static drops there.
On a step side, good luck squeezing a 10" wide wheel with a 6 or 7 inch rear drop. 12" wide wheel is definitely not happening without a mini-tub, but that may already have been in your plans. Lots of info around here on lowered wheel and tire fitments, these questions are asked regularly. Using the search function will net you hours of material to read and pics to look at.
So, are you going to be running a '5 speed & 540' in this new truck? We need details!
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 05-20-2017, 08:09 AM   #7
BossHogg69
motor exploder
BossHogg69's Avatar
I will add that a big block up front and a 5" drop will require a pretty stiff spring to keep the crossmember/lower a-arms from kissing the concrete, as it will likely only be a few inches off the ground.
Adam
Old 05-20-2017, 08:11 AM   #8
5spd540
It will be a small block the big block was in my 90 as truck I had
Old 05-20-2017, 08:10 AM   #9
5spd540
It's a step side truck and the bed is rotted to death so gonna tub it out and make it cool
Old 05-20-2017, 01:55 PM   #10
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I've driven 4/6 lowered trucks continuously since the late 80s. For me they just work. I haven't ever torn anything up that required repair.
I have owned a couple that were lower and you really need to be familiar with the roads or very diligent or you'll bash your front arms onto something. My current project is going down from 5/6 to 6/8 and I wouldn't want to drive it at night over unfamiliar roads unless I wasn't being rushed by heavy traffic and could pay real close attention to where I was going.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 05-20-2017, 02:45 PM   #11
5spd540
Yes I don't want to sacrifice the drivablility of it for looks. It not gonna be a daily but will get driven a good bit.
Old 05-21-2017, 06:28 PM   #12
68Stepbed
68Stepbed's Avatar
This is how my truck sat with a 4.5/6.75 drop. 18x9.5 wheels and 285/40/18 tires.
It's currently getting a TCI full front and rear coilover suspension, which should yield about a 5/7 drop. This is how she looks right now with no engine, fluids, or bed.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
