02-17-2016, 09:38 PM | #1 |
MY6 NP440 in a 64-66?
Anybody on the board ever put a MY6 transmission into a 64-66?
I'm currently working on the swap but even with the engine moved forward into the front frame tower holes the shifter is pretty far back past the trans access hole. And likely under the seat. My trans did come with a home made shifter mount but even with the stock one it'd be tight. Looking like I'll be making a new shifter mount bracket and bending new linkages. |
02-18-2016, 01:24 AM | #2 |
60-66 Nut
Re: MY6 NP440 in a 64-66?
02-19-2016, 10:43 AM | #3 |
For others coming later, here is the mount i made. I also used a hurst shifter handle that goes up, to the right 90 degrees like 4" then up again. Put's in pretty much center of the tunnel at that point. Bend is under the boot. I think i also tweaked it forward some.
Project "i'm just going to clean up the interior and the engine bay": http://67-72chevytrucks.com/vboard/s...d.php?t=550931 |
02-19-2016, 01:34 PM | #4 |
02-19-2016, 04:37 PM | #5 |
They did come with a factory Hurst shifter (I know my '87 did).
I can't tell if yours is. The fact that the shift handle slips into the base of the shifter would be a clue that it might be factory. Good job on the installation, by the way. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
02-19-2016, 09:43 PM | #6 |
Thanks Keith, little bending of the linkages and it should be good to go.
The shifter definitely looks close to the factory MY6 shifters I've seen, and I thought it was when I bought the trans, but the shift arms are a little different and it's listed for a 68/69 A body Mopar....but seems to still work fine. |
