08-07-2018, 09:10 PM | #1 |
Transmission advice
So, I have a 2006 LQ4 and 2WD 4L80. I plan on running my C10 (all time) AWD. I’ve picked up a NG149 transfer case and Denali front diff 3.73 to match the rear. I’m being told that I need to swap the 2WD for a 4WD as just swapping the output shaft isn’t an option. With that being said, I’m not opposed to going with a manual transmission but it must be a six speed if I’m going that route, but I’m afraid that’s not going to be an option with the AWD setup. The transfer case is being converted to 32 spline to make it work with the 4L80.
Advice and options appreciated before I buy something that I don’t need. Thanks in advance. Posted via Mobile Device Last edited by SimpleChaos; 08-07-2018 at 10:00 PM. |
08-07-2018, 09:21 PM | #2 |
Post Whore
Re: Transmission advice
WOW.....Welcome....
You've got a lot on your plate it sounds like...what year is the c10?... NG or NP?.....never beard of a NG... Sounds like quite a combination... Need pics btw
08-07-2018, 09:54 PM | #3 | |
Posted via Mobile Device Last edited by SimpleChaos; 08-08-2018 at 02:39 PM. |
08-07-2018, 10:08 PM | #4 |
Full time awd 6sp manual C10. Oh yeah... would be nice. The auto will do just as well. welcome to the board! -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
08-07-2018, 11:05 PM | #5 |
I have a lq4 out of an 06 that is 4wd. I need to go the opposite route and convert the 4l80 to 2wd. I was under the assumption you can change the output shaft and housing to accomplish this. Not sure why you cant do the same to convert yours to 4wd. As far as the t-case that came out of the truck it was a NP265. If only we were closer we could make a deal and solve each others issue.
08-08-2018, 07:26 AM | #6 | ||
As far as the 6speed, I'm not sure if a standard used T56 will hold the torque and I don't have the funds for a custom built bulletproof transmission. Was hoping to pick up something used or trade with my 4L80. The more I find out now, the better prepared I'll be when it comes time to shell out the money. So I guess depending on the two scenarios, I'm trying to go with the least expensive, yet most practical, option. |
08-08-2018, 07:27 AM | #7 |
08-08-2018, 10:15 AM | #8 |
Yes you do have to tear down the whole thing to change the output shaft as it's at the rear of the trans and you work from front to back.
08-08-2018, 11:13 AM | #9 | |
Posted via Mobile Device |
