Old 11-14-2019, 09:09 PM   #1
raidmagic
raidmagic's Avatar
Headers and the trans mount
1980 C10 1/2 ton. I put a new engine and trans (350/350) in the truck, when I bought it, it came with headers new in the box so I figured I'd use them too. Headmans. They fit great except my drivers side header points straight at the trans mount.
I could do some crazy angles on the exhaust pipe but it seems to me it's easier to just cut the trans mount in half and weld another piece to it and make it go straight across rather than dip down like the stock one does. I have an extra trans mount so I could use the pass side of that mount.
Any reason this won't work? Any other ideas aside from dipping the pipe? I have a nice set of pipes with an H pipe already and would like to just bolt it on.
Thanks for your tips.
1965 C-10 1/2 ton shortbed part time daily driver
1980 C-10 1/2 ton shortbed project
raidmagic is offline   Reply With Quote
Old 11-15-2019, 12:39 PM   #2
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: Headers and the trans mount
Get one from a pre 77 or so. No catalyst converter trucks have a double hump crossmember.
Or get an aftermarket tube style.
Old 11-15-2019, 08:49 PM   #3
1957 Chief
Proud Vet that loves the USA
What KQQLIT said, Just get a double hump crossmember.
Bubba
1957 Chief is offline   Reply With Quote
Old 11-15-2019, 11:44 PM   #4
KQQL IT
At the body shop.
KQQL IT's Avatar
No connection with them. But was a quality part.
https://m.facebook.com/Scorpionfabri...741954/?type=3
Old 11-19-2019, 09:31 AM   #5
sbeard73
sbeard73's Avatar
I got this one worked great.
https://www.ifabspeed.com/product-pa...ns-crossmember
1984 GMC Sierra Classic 1500
1935 Ford P/U
2012 Mustang GT/CS
1985 El Camino
1974 Ford Bronco
sbeard73 is offline   Reply With Quote
Old 11-20-2019, 05:51 PM   #6
raidmagic
raidmagic's Avatar
Thanks for the info. I just cut my stocker apart and re welded it to get the clearance I needed. I'm going to pick up a tubular one later. Thanks for the links.
