Old 01-01-2018, 08:13 PM   #1
Mr_Rich
Mr_Rich's Avatar
Door Roller Pins
I'm having to replace the hinge pins and bushings on my K2500. I replaced the pass. side roller pin with the Dorman part but I will probably use factory parts on the hinge pins. I was having a hard time pounding the roller pin in so I measured it with my caliper. The stock pin was about 0.57 in and the Dorman part was 0.59 in. Too large for an interference fit IMO. I put the pin in my drill and turned it like a lathe while grinding the knurled area down with my Dremel tool to about 0.58 in. That was enough for a good fit. The Dorman roller pin seems stronger than the stock part.
1989 K1500 Chev. EC
Original owner; some of the aftermarket parts I've installed are Borla headers, Hypertech chip, Edelbrock water pump, and a Stillen rear disc brake conversion kit.
2009 Hummer H3T 3.7L 5M (sold)
1997 K2500 Chev. EC 7.4L/ 4L80E
2018 Dodge Ram 2500 HD R/C
Mr_Rich is offline   Reply With Quote
Old 01-02-2018, 07:57 AM   #2
54 jimmy
54 jimmy's Avatar
Re: Door Roller Pins
just note a major cause of the rollers bending and breaking is bad door pin bushings and the roller it self not being lubricated. I have only ever had one bend and break due to all the above stated. not a fan of dorman products. had one of those break after fixing the door pins and bushings. ended up getting one from the factory junkyard. just my 2cents.
There is nothing you can't fix with a BFH or a FIRE WRENCH.
1997 chevy k1500 ext cab z71 (daily driver) sold
1996 chevy k1500 reg cab 4x4(daily driver)totaled
2008jeep patriot (wife's daily driver
2008 chevy 1500 ext cab 4x4 sold
2011 chevy 1500 crew cab ltz (daily driver)
1996 chevy 1500 reg cab 4x4 project sold
2006 pontiac grand prix gxp (daily work commuter)
54 jimmy is offline   Reply With Quote
Old 01-02-2018, 01:07 PM   #3
Mr_Rich
Mr_Rich's Avatar
I've kept my door hinges lubricated on my '89 and they're still in very good shape after almost 29 years. On this '97 it was abused and the hinge pins/ bushings are really bad.
1989 K1500 Chev. EC
