07-16-2017, 02:05 PM | #1 |
For those guys restoring their factory ac and heater boxes
Thought I'd post a video for you guys thinking about doing this to your boxes. It can be done to look very nice. Basically showing a before and after final assembly of the boxes describing all the parts that go to it.
https://youtu.be/Ickwhdl-1Hw |
07-16-2017, 02:35 PM | #2 |
Re: For those guys restoring their factory ac and heater boxes
On my list of things to do, thanks
1972 C10 Custom Deluxe LWB, 402/400, PS, PB, A/C, Highlander, Hugger / White 1971 C10 Cheyenne LWB (SWB), 350/350, PS, PB, A/C, Dark Olive / White. |
07-16-2017, 03:10 PM | #3 |
70+ ( Old Skool Club )
subscribed
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
07-17-2017, 01:12 PM | #4 |
07-17-2017, 01:44 PM | #5 |
Subbed
07-17-2017, 01:59 PM | #6 |
I did this, not as well though. I wish I could have removed my internal door (flapper) but guys on here talked me out of it. I was able to repaint the outside side, at least that won't rust.
07-17-2017, 02:07 PM | #7 |
First rate Benny, no question.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring it from ground up. With assys, the guide accts for 1000s of OEM identifications and part numbers, all written in short order. 700+ images include assm, illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
07-17-2017, 02:40 PM | #8 |
Thanks for uploading your product. Looks nice. Are you refurbishing for others?
Thanks again. |
07-18-2017, 10:56 AM | #9 |
07-18-2017, 03:37 PM | #10 |
Benny I couldn't have finished my rebuild without your help. First rate! Thank you sir.
1971 Longbed BB Cheyenne Super 1972 Longbed SB Cheyenne Super 1972 Longbed Highlander Custom Deluxe 1975 K5 4x4 full convertible Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=645165 Greg Smyrna TN |
07-19-2017, 03:55 PM | #11 |
07-19-2017, 06:51 PM | #12 |
On my list. Subscribed.
(Very) Slow-Going Build Thread: Stock 1970 Short Step with Stock 1970 LT-1 http://67-72chevytrucks.com/vboard/s...d.php?t=567340 |
07-20-2017, 07:21 AM | #13 |
Benny if you can please post pictures and document the work you do on apacheIvan's truck. Of course with his permission. His truck is a great example of what a lot of folks are dealing with on their A/C.
07-20-2017, 10:10 AM | #14 |
Benny refurbished my ac box and heater box. He did a great job!
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach "Wanda" Don't argue with idiots, People watching may not be able to tell the difference... There's someone in my head........But it's not me...... cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
07-20-2017, 11:32 AM | #15 |
Florida Edition
Hi Banny, sorry I forgot to let you know we received the A/C unit you sent us (I have yet to install it). You do excellent work, thank you very much.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
07-21-2017, 09:57 PM | #16 |
07-21-2017, 11:10 PM | #17 |
Benny said he doesn't service the AC I was going to take it to him for help..
Dale - ApacheIvan 1972 Chevy Custom/20 Custom Camper Highlander http://67-72chevytrucks.com/vboard/s...d.php?t=740479 Original Owner ** Do you have a 1972 Plaid Pickup?** |
07-21-2017, 11:12 PM | #18 |
Hey Benny, what did you use on the outside of the box once you had it all clean. I stripped all the paint off mine, it looks very light, did you use any clear over it or use any product once you have it clean?
07-21-2017, 11:37 PM | #19 |
I guess i shouldn't have put it that way. What I meant by not doing service work is that I primarily do restoration of the parts. I can and have taken jobs when it was a complete restoration with installation where the owner is in no hurry. And that's pretty much the only service type jobs I take. Because the parts restoration jobs take up most of my time. And yes the housings are bead blasted and cleared.
07-22-2017, 12:01 AM | #20 |
ApacheIvan, if you would like to take it to a place that works with r12, check out McCain's A/C auto repair in Dallas. They work on classics and still work with r12.
07-22-2017, 12:05 AM | #21 | |
I will look them up. Do you think I should just get the r12 muffler, disassemble everything and clean it out, buy a new drier and put it all back together dry?
07-22-2017, 12:12 AM | #22 |
You can do that. Then just take to them and have them charge it
07-22-2017, 12:20 AM | #23 |
Do you recommend I put oil in the system when I put it back together? When I put it together the first time the guy that put in the r134 said I was supposed to pre-oil the compressor, put oil in the condenser and drier. Is that right? If so, I think our systems are supposed to have 8oz of oil. Do I put all 8 in before sealing it all up? then they just put the R12 in it?
07-22-2017, 12:27 AM | #24 |
I would do that but it's 11 oz
07-22-2017, 12:42 AM | #25 |
Thanks, so put all 11 oz in before sealing it up? You actually put oil in the drier too?
It is 3.25lbs of R12 yes?
