Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1988 - 1998 GMT400 Chevy & GMC Pickups Message Board > projects and builds 88-98
Old 09-17-2018, 05:37 AM   #176
Terrick down Under
Terrick down Under's Avatar
Re: Fastfreddys 454ss
Well done, hard work has paid off!
Terrick down Under is offline   Reply With Quote
Old 10-14-2018, 08:54 AM   #177
68 TT
Still plays with trucks
68 TT's Avatar
Lots of great ideas and research for mods to our trucks. Great work.
I wanted to add that putting the closed chamber 396 heads on would have been a mistake just to raise the compression. The valve size is no bigger and the flow of the heads isn't enough better to be worth the effort and expense of rebuilding them. The closed chamber 396 heads have a bad valve shrouding issue in stock valve size with higher lift cams and it becomes a severe hindrance to air flow if you put the 2.19 & 1.88 valves into them. The later model open chamber versions like the 049 casting flow substantially better and are the one to go with if you want a large oval port stock head on an engine.
That being said the peanut port heads on our TBI 454 engines have a whole lot more performance potential than most people give them credit for. Even with the stock valve size they flow enough air to make some pretty good power in naturally aspirated form on an engine with good compression, a decent sized cam and a good flowing top end and exhaust. These were all the reasons the heads have a poor reputation to begin with. The stock compression is pathetic, the cam is unbelievably tiny and the intake & exhaust systems choke down what little air could get to or out of the heads so heavily that they never had a prayer of making any decent power in a stock TBI 454. With your supercharger, better intake, bored out TBI and headers all you need is a cam with the correct profile to work right with boost and still be computer control friendly so it is tunable and you are good to go.
67 C10 Suburban The Ant Farm http://67-72chevytrucks.com/vboard/s...82#post6095882
69 C10 shortbed stepside project 45 ACP http://67-72chevytrucks.com/vboard/s...13#post4899613
69 K20 lwb TBI 400 4L60E NP208 square body chassis http://67-72chevytrucks.com/vboard/s...=1#post3955165
68 Camaro SS / RS 500hp 439 inch big block T-400 http://67-72chevytrucks.com/vboard/s...d.php?t=528952
79 Malibu TPI 350 4L60 3.73 gears
68 TT is offline   Reply With Quote
Copyright ©2000 - 2018, vBulletin Solutions Inc.
