Old 02-01-2018, 06:26 PM   #1
eighteenninetytwo
What now??
Just got a call from the Electrical guy who was taking my 75 to teh Radio guy.
Driving down the freeway - massive amount of smoke, and oil sprayed ALL OVER the carburettor underside top of engine - EVERYWHERE!! he let it cool and limped back to his shop.
Oil is still full and clear. Only thing i can think of is that under pressure at speed (though he said he was doing 55) a seal is failing that doesn't normally get impacted. Anywhere i shoud look first when i get there. Filter and drain plug still in place.
I recenntly had the cylinder heads gone over due to blown head gasket.
on my way up there tomorrow - Any thoughts/ theories??
eighteenninetytwo is offline   Reply With Quote
Old 02-01-2018, 06:35 PM   #2
kwmech
Re: What now??
Oil pressure sending unit comes to mind if it is "spraying all over". Unit is next to the distributor
Old 02-03-2018, 01:27 AM   #3
Irish1941
Irish1941's Avatar
Re: What now??
Exactly what I was thinking.
Mechanical oil line let go.
Didn't you just do head gaskets? Something not get sealed up right?
Irish1941 is offline   Reply With Quote
Old 02-08-2018, 11:24 AM   #4
mickeykreg
mickeykreg's Avatar
Re: What now??
Did you figure out the culprit on this?
'80 SRW C35 - 355/700R4/4:11/2.5-3/DD
'77 Cheyenne K5 - Roller cam 355/NV4500/205/4:88's/35's/DD
rust repair on the '77
http://67-72chevytrucks.com/vboard/s...d.php?t=740291
mickeykreg is offline   Reply With Quote
