Old 03-29-2013, 04:26 PM   #326
1955GMC
Re: Yet another GMC build
I love this truck, the stance is perfect and it looks very fast while sitting still.
I'm posting because after I first started reading your build thread I have been watching Craig's List and E-Bay for wheels at the bargin prices you mentioned on the first few pages. I finally found a great set of '03 Vette 5oth aniversary thin spoke 17 and 18 inch wheels for under 400.00 for the set. Took me some time but bargins can be had.
1955GMC is offline   Reply With Quote
Old 05-06-2013, 05:05 PM   #327
OKGMC4
OKGMC4's Avatar
I did some research on intake air temps and found that not only is colder air better than hot for performance but an injected engine makes this even more so....as the intake air temp increases the ecm retards timing accordingly. That means you're losing power and probably fuel economy as well. I borrowed an idea from JML55's truck and got rid of the top mounted airbox, but did my new airbox in fiberglass rather than stainless. Inside is a cone filter fed through the core support. I verified before and after with live data from my OBDII scanner and I have dropped my IAT by 47 degrees on a 55 degree day from 109 down to 62. And that's sitting still idling. It does run smoother and quieter but I have no way of verifying any power increase.
With the top box out of the way I decided to do an intake cover. I took a new camaro cover, cut out the center and bolted it together with an aluminum strip and bonded it with epoxy. Filled the oil fill hole with an old wheel cap and painted it silver with orange flames. On the last piece of tape some of the silver lifted so rather than repaint the whole thing I brushed a black outline on all the flames to hide the screw up. Not as nice as I wanted but I can redo it later. It's sunny outside so I'll just drive it awhile...
56 GMC BUILD THREAD:
http://67-72chevytrucks.com/vboard/s...d.php?t=368649
69/67 chevy/gmc LS powered unibody:
http://67-72chevytrucks.com/vboard/s...d.php?t=624747
One piece window conversion Blackdiesel style:
http://67-72chevytrucks.com/vboard/s...d.php?t=366078
OKGMC4 is offline   Reply With Quote
Old 05-06-2013, 05:29 PM   #328
Kim57
Kim57's Avatar
Looks good.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 05-11-2013, 06:35 PM   #329
mknittle
mknittle's Avatar
I may be a little different but I like it better without the cover over the air filter.
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 06-12-2013, 05:08 PM   #330
JMac11
JMac11's Avatar
What did you do with the first box you built..... looking to put something similer together under a cowl hood.
JMac11 is offline   Reply With Quote
Old 06-13-2013, 07:49 PM   #331
OKGMC4
OKGMC4's Avatar
Sittin in the shed gatherin dust. Can't stand the idea of tossing it, hours of work went into it.
Old 05-21-2014, 07:33 PM   #332
OKGMC4
OKGMC4's Avatar
Back at the beginning of the month I took the truck to the drags and it ran consistent 14.5 and 14.4 second times. Not too awful for a stock 5.3 with 3.08 gears. Had a fun time but now the truck has left town to live with my parents while I start the next project. Just not enough space. I've started a 69 chevy that will become a GMC with an LS motor and some heavy body mods. The link is in my sig if anyone is interested.
Old 05-21-2014, 08:44 PM   #333
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Very nice work on the air filter relocate. I'm sure it's nice to be able to drive it now. I agree about just driving it now. Might as well while the weather is good for it.
Ryan
1976 K30 CC SWB Build Thread
Old 01-31-2018, 08:20 AM   #334
OKGMC4
OKGMC4's Avatar
Been driving the truck a few years now and put 15K miles on it. Need to do some freshening to get it back on track. Kind of neglected it while Iíve been focused on the unibody build. Steering wheel was never perfect but wanted to get rid of the brushed look and get a wheel wrapped tighter than I did it all those years ago. When the grant adapter stripped out it was the last straw. I bolted on the 9 bolt adapter that came with the column and ordered a new LeCarra. Have more plans, and will execute them in the near future.
Old 01-31-2018, 08:22 AM   #335
OKGMC4
OKGMC4's Avatar
Old wheel
Old 01-31-2018, 02:57 PM   #336
iowaboynca
iowaboynca's Avatar
thanks for the update. Glad to see its being driven!
Build: "1950" GMC -Charlotte
iowaboynca is offline   Reply With Quote
Old 02-07-2018, 10:40 AM   #337
OKGMC4
OKGMC4's Avatar
Not all the play was eliminated in the steering so I checked the rack. It was fine. Took the column apart and it was worn near to breaking at the tilt swivel. Did some investigation and it turns out the Chinese columns are terrible, and I had the worst one. The one made by Helix. More info here...
https://www.lvvta.org.nz/documents/i...ng_Columns.pdf
I am in the process of installing the (better) column i bought for my 69. Itís not chrome so Iím painting it to match. Weíll see how it turns out.
Old 02-08-2018, 06:22 PM   #338
OKGMC4
OKGMC4's Avatar
New column in and working well. The steering with the cheap eBay Chinese column was never this tight. Lesson learned.
Old 02-08-2018, 06:34 PM   #339
OKGMC4
OKGMC4's Avatar
The turn signal cam isn’t mushy on this one and I don’t have to manually turn off the blinker after making a turn. Bonus!
Old 02-09-2018, 11:59 AM   #340
NeoJuice
what brand did you replace it with? ididit? flaming river?
NeoJuice is offline   Reply With Quote
Old 02-09-2018, 12:37 PM   #341
Mains52
Very Nice Sir. That orange has a special place in my heart via my first car. Nice choice.
Mains52 is offline   Reply With Quote
Old 02-09-2018, 01:05 PM   #342
OKGMC4
OKGMC4's Avatar
The column is a CPP. I know the article says they are not as good as the FR and Ididit columns but it looks like the biggest issue was the quality of the plastic swivel ball. I took this one apart and inspected it beforehand and it seems fine. I already had it, it was supposed to go in my 69 c10 but that truck isnít finished yet. At least it has the failsafe built in like s GM tilt column. The Helix column does not, so I could have potentially lost all ability to steer.
Old 02-09-2018, 01:08 PM   #343
OKGMC4
OKGMC4's Avatar
Thanks! I always wanted a 69 GTO in that color, and I grew up watching a certain Charger jumping creeks in Hazzard county so it seems the color was predestined to happen. Sure gets a lot of attention!
Old 02-09-2018, 01:11 PM   #344
OKGMC4
OKGMC4's Avatar
A Summit box arrived today. It’s like getting a box full of shiny gold coins. Several parts to perform the next few upgrades.
Old 02-09-2018, 06:00 PM   #345
OKGMC4
OKGMC4's Avatar
I installed a secondary trans cooler under the radiator. Never had an issue with overheating in general but want to be prepared for what comes next.
Old 02-14-2018, 05:14 PM   #346
OKGMC4
OKGMC4's Avatar
One thing that has bothered me is the high ride height and stiff ride. The vette transverse spring was too low and bottomed out. I put on coil overs and QA1s best guess for me was 400 lb springs. They were also too low. Out of cash and strapped for time I ran all three springs. No more pot hole terrors. According to QA1 what I’m doing is a big no-no and the springs added together make for a race car-like 700 lb rate. I bought a pair of 200lb springs and swapped out the 400 pounders. Hard to see in the pic but it's about 1" lower. Rides softer, sits lower, no banging the pavement. Going to roll with it for a while, see what happens.
Old 02-16-2018, 12:00 PM   #347
OKGMC4
OKGMC4's Avatar
The springs ride much better. And the suspension settled a hair more and looks perfect. Also the handling has improved. Before when I hit a fast curve the front wouldnít even lean, which means the tires never took a set or got any bite. The front would just slide in a massive case of understeer. Yesterday on the way home I took a certain S curve at 70mph that before was frightening at 50. One of these days I want to upgrade my C4 front brakes to C5 spec. Supposed to be a night and day braking upgrade.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
