Old 11-30-2015, 08:06 PM   #26
6t9camaro
6t9camaro's Avatar
Re: 67 C10 "Green Gobblin" straight from the field!
Heres a few updates! I got the cab front end torn down and off the trailer. I had a few scary moments lifting it with my engine lift and straps! ( not recommended!!!) I modified my rotissorie to fit the cab so Now she's spinning and i can get a good look at the underside. Its pretty bad so i ordered up a complete floor/rockers/cab corners.
6t9camaro is offline   Reply With Quote
Old 11-30-2015, 08:16 PM   #27
6t9camaro
6t9camaro's Avatar
A few more
Old 11-30-2015, 08:18 PM   #28
Valarius_Starchaser
Valarius_Starchaser's Avatar
Nice work man!
Keep the updates coming
Valarius_Starchaser is offline   Reply With Quote
Old 11-30-2015, 08:23 PM   #29
6t9camaro
6t9camaro's Avatar
More rotisserie! Plus a few pics of the nest that was in the heater core area! One thing i hate is digging out nests!!! If my wife or kids ever saw this they would never ride in this truck!!!
Old 11-30-2015, 09:31 PM   #30
68Gold/white
You planning on a Vintage air unit?
68Gold/white is offline   Reply With Quote
Old 11-30-2015, 10:06 PM   #31
6t9camaro
6t9camaro's Avatar
No not really planning on vintage air! Trying to keep this truck low $$$.
Old 12-02-2015, 12:21 AM   #32
swamp rat
swamp rat's Avatar
Curious how you came up with your balance point on the rotisserie mounts in the door jamb? i see the povot is forward of center. And can i assume the forward point is also bolted using the top door hinge mount?
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 12-02-2015, 01:07 PM   #33
6t9camaro
6t9camaro's Avatar
I just placed the pivot point in the center of the cab and not center of the door. the forward point is just below the upper door hinge. I didn't spend to much time trying to create a balance point as i just wanted to flip the thing over! Its still a little firewall heavy but I'm hoping it will balance a little better once all the dash and steering column is out. Heres a quick pic of the door bars i made to match up to my existing rotisserie. ( pretty simple )
Old 12-02-2015, 02:38 PM   #34
68Gold/white
Lol, I think your low budget plans are already shot...
I grew up in Iowa, North Dakota may not be the place for needing A/C, I keep forgetting....
Keep up the great work!!!
Old 12-03-2015, 05:22 AM   #35
swamp rat
swamp rat's Avatar
Thanks for the pic!
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 12-29-2015, 08:58 PM   #36
6t9camaro
6t9camaro's Avatar
Finally got a chance to sit down and give you guys some updates! Since I'm waiting on my parts order i dug into the 72 parts truck. Heres a few pics! its a 72 lwb custom with the original 350/350. Apparently ran and drove until the previous owner had a carb fire and he gave up!
Old 12-29-2015, 09:14 PM   #37
6t9camaro
6t9camaro's Avatar
Ok now for the good ole burnt up 350! i figured it was a total write off and if nothing else it would be good for a rebuild. After i stripped away and swapped out all the burnt up stuff like Dist, wires, carb, hoses and drained out about 10 litres of oil and water and popped in a new set of plugs she fired up and ran like a champ!!! Oil press was 50psi at start up and 30psi warm. I gave it a compression test and was at 130psi on every cylinder! It passed a leak down and its going to be good enough to clean up and slap into the Green Goblin!
Old 12-29-2015, 09:24 PM   #38
6t9camaro
6t9camaro's Avatar
Now with my new found motivation since the motor runs i stripped the rest of the truck down to see what i might be able to use. Other than all the 5 lug swap parts i will need the dash and part of the firewall.
Old 12-29-2015, 09:30 PM   #39
6t9camaro
6t9camaro's Avatar
Since its getting cold and the snows piling up i figured id grab the firewall before the whole trucks buried! Thats about it for the 72!
Old 01-05-2016, 08:22 PM   #40
6t9camaro
6t9camaro's Avatar
Ok I finally got my parts!!!! Thanks LMC and summit! New floor, rockers, cab, corners, fender skirts, Rad support, basically all the metal to do this job is here Plus a ton of misc stuff out of the LMC Catalogue! A nice pair of 15x8 6 lug wheels and all the Heater box,core and controls from a few fellow board members. I actually think i might have ordered to much stuff as I'm running out of room to work on it now! But my kids happy with all the boxes!!!
Old 01-05-2016, 08:29 PM   #41
6t9camaro
6t9camaro's Avatar
Heres a few pics of the floor and firewall. I gotta say the floor is a nice piece! if anybody is thinking of doing a lot of floor work this is the way to go!
Old 01-05-2016, 11:42 PM   #42
dfwright
dfwright's Avatar
Wow! That is some haul of parts! Looks like you will be pretty busy!
1972 C10 LWB, 350/350
Deconstruction began 5/2009, mostly completed restoration, 5/2017
dfwright is offline   Reply With Quote
Old 01-06-2016, 03:03 AM   #43
swamp rat
swamp rat's Avatar
Who did you get the floor and firewall from if ya don't mine my asking? Great news on the engine too!
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 01-06-2016, 09:33 AM   #44
6t9camaro
6t9camaro's Avatar
The floor came from lmc and the firewall I actually picked up from my local truck/parts shop as it wasn't in stock anywhere else. Both pieces are tri-plus and look pretty good!
Old 01-06-2016, 04:23 PM   #45
67chevy1series
67chevy1series's Avatar
Looking good, love the forest green on the 67's are you planning on keeping the patina green if possible or repainting it?
67chevy1series is offline   Reply With Quote
Old 01-06-2016, 04:54 PM   #46
collin70k/20
collin70k/20's Avatar
Keep the progress coming.
collin70k/20 is offline   Reply With Quote
Old 01-06-2016, 07:23 PM   #47
Sicksty8
Sicksty8's Avatar
Truck looks a lot like mine! I'll be along for the ride. Just for s***'s 'n gigs did you pick up that parts truck from somewhere up in the great wide manitoban north?!
Sicksty8 is offline   Reply With Quote
Old 01-06-2016, 09:23 PM   #48
6t9camaro
6t9camaro's Avatar
Thanks! I like the green 67s also that's pretty much the reason I bought it! Lol
The plan is to keep the patina as is and build the truck as a safe/fun driver for me and my kids. I'm fixing all the underside rust and a few ugly spots like bottom of fenders/box and blend them out to match the rest of the truck. I will redo the interior to keep it Clean and simple so the wife might even want to ride around in it!?
Old 01-06-2016, 09:38 PM   #49
6t9camaro
6t9camaro's Avatar
Wow Sicksty8 I just checked out your thread and ya they look like twins! And yes i picked up the orange 72 parts truck and my green 67 from Manitoba! That's why there's so much rust! Lol
Old 01-06-2016, 11:40 PM   #50
Sicksty8
Sicksty8's Avatar
That's pretty funny because I'm pretty damn sure you beat me to buying that 72! Yeah almost every truck I've checked out here in manitoba has a crapload of rust. I'm also just a bit jealous of your parts pile Looks like fun!
