Old 11-30-2019, 10:28 AM   #1
MD2020
Help with the bottom side of Hood
What coating or cover would you put on the underside of your hood
MD2020 is offline   Reply With Quote
Old 11-30-2019, 11:37 AM   #2
my56chevytruck
my56chevytruck's Avatar
Re: Help with the bottom side of Hood
How much are you planning on driving your truck? I simply painted the underside the same as the entire truck, no problem. Go to GOOGLE and type in painting underside of hood and click on Eastwood's article.
RUBBER DOWN AND HIT THE ROAD!!!
1940 Ford Dlx Coupe
1969 Mach1
my56chevytruck is offline   Reply With Quote
Old 11-30-2019, 02:09 PM   #3
_Ogre
_Ogre's Avatar
body color paint works for most of us
don't use undercoating it will be to heavy for the springs
shop air compressor timer
Old 11-30-2019, 03:40 PM   #4
MD2020
Thanks guys
Old 12-01-2019, 11:06 PM   #5
Driver_WT
Driver_WT's Avatar
I cleaned the bottom of the hood with the wire wheel on my angle grinder (there was surface rust on the bottom side of the hood). Then brushed on POR 15. Then my painter painted the bottom side of the hood body color.
Wade
53 Chevy 3100, SBC 355, 700R4, S10 frame, Ford 8.8 rear with 4.11 gears, front disc & rear drum brakes
Driver_WT is offline   Reply With Quote
Old 12-04-2019, 01:47 PM   #6
Marty68
Marty68's Avatar
spi black epoxy.
Truck goals... 0-70 then 70-0 safely
Marty68 is offline   Reply With Quote
Old 12-04-2019, 03:07 PM   #7
mr48chev
mr48chev's Avatar
As several others painted body color. If I was going for a plainer look I'd paint it inner fender black.
Mine has 120 louvers in the hood so any kind of coating would make a mess.
I had a hood one time that someone had undercoated and it was heavy. I think I ended up hauling it for scrap as it was too much trouble to clean the mess off it.
The only possible viable reason for putting any other coating on the bottom side of the hood is if you didn't want engine noise getting out what there is of it. Not too many AD truck folks are very worried about that.
My ongoing truck projects:
Copyright ©2000 - 2020, vBulletin Solutions Inc.
Copyright 1997-2020 67-72chevytrucks.com
