12-31-2009, 12:35 AM | #1 |
72 GM Temp Guage Problem
The temperature guage is all the way to the right side of the guage? It had worked but is now on the hot side, Why? What should I look for?
12-31-2009, 01:23 AM | #2 | |
Re: 72 GM Temp Guage Problem
It's either hot (jk)or the wire is shorted to ground (which includes bad sending unit) disconect the wire from the temp sender and see if it comes down if yes sender is bad if no wire is shorted to ground
1965 GMC shortwide big window 1969 Chevy C20 long (for now) 2005 Silverado 2500HD Crew Cab Quote:
12-31-2009, 01:29 AM | #3 |
When unplugged guage does not come down. Could the problem be right in the fuse box? I have put in new circuit board, resistors, guage, temp sender. I pulled the connector off of fuse box in engine compartment side and all looks well. Could it be in the inbetween part of the fuse box?
12-31-2009, 01:39 AM | #4 | |
If you pulled the wire from the fuse box in the engine comparment side and the gauge went down the short is between there and the sending unit possibly on the exhaust or pinched
