Old 04-08-2013, 08:17 AM   #1
tydenney
starter problems with engine swap for 68 c10
Hello all,
I swapped my I6 for an 80's 305, got it in and the last issue is the starter. I can't get it to fire. I noticed on my old I6 and starter it has 2 wires, but the new one has three. Any advice?
tydenney is offline   Reply With Quote
Old 04-08-2013, 09:51 AM   #2
Shyguy
Junior Member
Shyguy's Avatar
Re: starter problems with engine swap for 68 c10
Ok first you say you can't get it to fire. Do you mean that the starter will not turn over or the engine will not fire.
The starter with three wires were used for engines with point type distributors, but can be used for others. The positive wire from the battery is hooked up to the large bolt on the starter and a small wire is hooked up to one of the small bolts from the ignition switch, I think it is the purple wire if my old memory is right.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 04-08-2013, 11:02 AM   #3
68gmsee
Active Member
68gmsee's Avatar
I have some saved pics of wiring from this site:
Early and later solenoid wiring.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 04-08-2013, 05:54 PM   #4
Shyguy
Junior Member
Shyguy's Avatar
Thank you for posting the pictures. I think I will save them to the folder I have for info on these old trucks.
Old 11-22-2017, 07:38 AM   #5
Desy180
Thank you for your good answers, useful.
Desy180 is offline   Reply With Quote
Old 11-22-2017, 02:49 PM   #6
Steelheader
Steelheader's Avatar
Since we're on the starter subject I would highly recommend making sure starter bracket is installed ( keeps starter from "racking" and cracking your block ) and properly shimming prior to trying to turning over . You can check clearence between starter and flywheel with an allen wrench . Just a couple simple steps that could save you a lot of grief .
Photos from internet .
Steelheader is offline   Reply With Quote
Old 11-22-2017, 02:55 PM   #7
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Not sure if all engines have that front starter bracket. I personally have never used or owned a rig with a SBC that had that front bracket on the starter. I have never had a block crack.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 11-22-2017, 04:19 PM   #8
Steelheader
I've seen two blocks over the years that have cracked in the same location and were welded up to be repaired , the bracket can be found for under 10 bucks and is just cheap insurance in my opinion . I don't think you have to have them but for the inexpensive cost and fairly easy to install I will always use them where applicable .
