02-26-2018, 10:52 AM | #1 |
Question for Task Force Owners
What are you doing for windshield defrost / defog ? What was on these trucks originally ? I need help.
http://67-72chevytrucks.com/vboard/s...d.php?t=740665 |
02-26-2018, 08:21 PM | #2 |
Re: Question for Task Force Owners
Mine had a stock deluxe heater, worker very well. Now it has a VA system with AC, but has not been tested. Good sized heater core and good air flow so I expect it to be the same. If yours did not come with deluxe heater there are lots of old box units that will work, usually have flap doors for cab heat and a couple of round flanges on top for defrost hose.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
02-26-2018, 08:44 PM | #3 | |
02-26-2018, 09:23 PM | #4 |
Thanks for the response . I think I am going to do a Vintage Air unit.
03-11-2018, 05:31 PM | #5 | |
03-11-2018, 06:30 PM | #6 |
Thanks for checking for me OrrieG been looking all over. Only work on my 55 project during the winter months when I am in Florida. Sorry did not mean to hijack this thread just saw that you had, had a deluxe heater and have been look for one for a while now. Cheers
Posted via Mobile Device |
03-11-2018, 06:52 PM | #7 |
I used a universal cab heater from Summit Racing, tucked up under the dash where the glove box used to be. It has dual fans and moves a ton more air than the original Deluxe heater.
03-11-2018, 07:45 PM | #8 | |
Got 2 recommendations for you. Get the deluxe controls and consider the upgraded side vents. Both are wonderful options. |
03-12-2018, 01:25 PM | #9 |
the original defrost adapters screwed under my dash worked fine with the va system, the va replacements are short
i used a hybrid system under my dash instead of the va surefit as i didn't want the plastic heater duct my hybrid consists of the surefit condenser/dryer/trinary up front and the compac mini under the dash works very well, will run you out of the cab in either heat or cool function unlike orrieg i never had much luck with the stock heaters, they would barely keep the windshield clear, much less any heat into the cab extreme sub-zero winters in montana, wyoming and colorado: nothing you will encounter in la
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer Last edited by _Ogre; 03-12-2018 at 01:31 PM. |
03-12-2018, 07:24 PM | #10 | |
I used the VA outlets on mine, but kept the stock ones just in case. I found I had to connect the hoses to the outlets before screwing them up to the bottom of the dash.
03-12-2018, 07:52 PM | #11 |
My VA defrost vents work and fit just fine. Both on my pickup and '55 Bel Air.
Nice and light too. |
03-12-2018, 09:57 PM | #12 |
I spoke with Vintage Air today. They don't sell a sure fit for a 56 GMC. They told me that there was less room in the GMC dash and the Chevy Surefit would not fit in my GMC . They recommended a gen 2 mini. What are you GMC owners using ?
03-13-2018, 12:55 PM | #13 |
the mini and compac are similar size, mini is .3'' narrower and .5'' shorter
not sure what is different between the gmc/chevy in the passenger dash area but it would be similar to my install the va system was one of the 1st things roughed in the cab as i wanted to weld in brackets and figure hose routing then it went back into the box to outlive the warranty by 4 years before i first charged the freon
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
03-19-2018, 11:59 AM | #14 |
Quick and simple fix - I just use RainX inside and outside the windshield. Works like charm. I don't drive my truck in the winter, but it sees a lot of road time in the spring and fall.
Just because you can, doesn't necessarily mean you should. 1959 3100 stepside 355 + T5 |
03-19-2018, 08:31 PM | #15 | |
03-19-2018, 10:27 PM | #16 |
Thanks OrrieG sent you a PM
03-20-2018, 11:54 AM | #17 |
