Old 10-30-2018, 10:36 AM   #1
SunSoaked
SunSoaked's Avatar
Th400 Modulator/Shift question
I'll admit I'm ignorant on this topic. Only ever dealt with a 700r4. Got my Th400 back from the shop yesterday, fully rebuilt. I noticed the vac modulator has a red stripe on it (I see black striped ones available as well). Internet search suggests that it's adjustable? Does adjusting it only affect the shift points at WOT? How does adjusting the modulator differ from installing a "shift kit"? They installed a mild shift kit because we both agreed the really hard shifts are annoying on a typical daily driver.
SunSoaked is offline   Reply With Quote
Old 10-30-2018, 11:27 AM   #2
sweetk30
sweetk30's Avatar
Re: Th400 Modulator/Shift question
i know the red strip is most popular upgrade unit guys use .
it basicly lets you fine tune the point of shift a bit . nothing crazy .
try it first and then play from there .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 10-30-2018, 08:30 PM   #3
Chevyrestorerman
Looks like you had to rebuild the ol 400 transmission after all...
is this the truck that got vintage air, any pics of that install ?
Chevyrestorerman is offline   Reply With Quote
Old 10-30-2018, 10:00 PM   #4
SunSoaked
SunSoaked's Avatar
Ya, it started making noises that suggested it was about to give up the ghost. As far as the Vintage Air, there's not much to see. Everything fits up under the dash. The firewall gets a block off plate. I'm very satisfied with it. It was a pleasure getting rid of all the factory wires, vacuum hoses and relays. Blows 43 degrees out the vents on a 120 degree Arizona day.
Old 10-31-2018, 08:33 AM   #5
Chevyrestorerman
Its a great way to show off your truck's vintage air install, post pic's so others can see how it was done. Thanks in advance.
Old 11-04-2018, 04:45 PM   #6
crazy longhorn
Fabricate till you "puke"
My thoughts, are that the modulator, is adjustable for fine tuning on the shift points. I would run the trans as set up, & see how she feels. If you are running lower (numerical gears), you will do better using a govenor recurve kit, to set the shift points. You can use the vac modulator, to fine tune your shifts. Best of fun.....crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
