Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Welcome and Discussion > General Discussion
Old 08-28-2004, 09:07 PM   #1
Robo_bot
Robo_bot's Avatar
Exclamation O/T Nova Power Steering Box???
my buds got a 73 Nova and he wants power steering and i was looking at the classic performance web site and i could have sworn the truck power steering box's and the nova ones are the same what car can he pull a power steering box out of that would work on his car do u guys know i know all of the look alikes like a Omega Ventura and Firebirds but anything more common???
thanx Nick
Robo_bot is offline   Reply With Quote
Old 08-28-2004, 11:48 PM   #2
tmcgrawlookalike
why not go to the parts store and get a reman gearbox for a `73 nova`.not that you can`t find one at a salvage yard,as i know,i work at one.it`s a common problem with one that age for the seals to be hard and brittle,therefore leaking faster than you can pour fluid in,besides having other issues as just being wore out.just my 2 cents
tmcgrawlookalike is offline   Reply With Quote
Old 08-29-2004, 03:41 AM   #3
jimfulco
A truck box won't fit. Many GM cars from the late '60s through the early '80s can use each other's steering boxes. They changed the hose connections in '77, but you can get adapters or have hoses made at a hydraulic shop. Get a pump & brackets from a long-water-pump engine ('69-up cars, '73-up trucks).
jimfulco is offline   Reply With Quote
Old 08-29-2004, 04:36 AM   #4
jlmtrout
As I understand it, the truck steering box mounts outside the frame, and car boxes are mounted inside the frame. As far as interchangeability, go to the library and look it up in the parts interchange book. That will give a list of all models that will fit. Good luck and keep on truckin'........Jerry
'68 c-10 long wheelbase fleetside, been in family since new, originally 250 3 speed
Now (389) 350 .060 over 3.75 stroke,Edelbrock Performer RPM 70cc heads and Intake
600 cfm Edelbrock,Small Comp Cams retro-roller cam and roller rockers,9:1 cr, headers, HEI,Old Air a/c, 72 power disc brakes w/stainless lines, 3.42 gear,T-56 6-speed, original paint(what's left of it). Dakota Digital Dash
jlmtrout is offline   Reply With Quote
Old 08-29-2004, 01:07 PM   #5
Robo_bot
Robo_bot's Avatar
ok thanx guys for all the help
Nick
