01-22-2020, 06:39 PM | #1 |
T-5 trans info needed please
Good afternoon guys n gals.
Got another Manual trans question for you guys. Might be doing some trading for a T-5 from a V8 Mustang as a 'Parts' trans since I have another (internally complete) T-5 from a early-mid 90's S-10. Question is, Do the internals swap out and would the Ford internals be tougher since it was from a V8 instead of just a V6, like the S-10? If not, probably not worth my time..? Projected engine will be either a hopped up .060 283, or a warmed over std 327. So nothing upwards of 400hp lol.. Pretty much all I need is a small hole bellhousing and fork for the S-10 T-5 (got some contacts. But nothing yet) Thanks E |
01-22-2020, 10:27 PM | #2 |
Re: T-5 trans info needed please
Ford input shafts are different lengths, spline count, and pilot diameter different than the GM trans.
You can adapt a Ford to GM and if you Google "mustang t5 c3 Corvette" you can find a lot of that info. You need to have some customer pieces and cost will go way up.
01-23-2020, 04:52 PM | #3 |
Thanks Mike. I'll give it a read.
....Ok, looks like it's NOT going to help me for what I'm trying to do. E Last edited by rockosocko; 01-23-2020 at 05:01 PM. |
