Old 06-23-2018, 10:31 PM   #1
Miller230
72 k20 Dana 44
Rebuilding a Dana 44 on my 72 k20 and came across the drivers side spindle bearing having a brass washer backed up on it and the passenger side not haveing one? Is this correct or has someone worked on this prior to me owning it?
Miller230 is offline   Reply With Quote
Old 06-24-2018, 04:16 PM   #2
mongocanfly
Re: 72 k20 Dana 44
Welcome
Got a pic of what your describing?
Mongo...aka Greg
1981 c30 lq9 nv4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598
1955.1 ls3 tr6060...(under construction)(on hold)
2013 gmc z71. (daily driver)
Old 06-25-2018, 12:22 PM   #3
B. W.
B. W.'s Avatar
Re: 72 k20 Dana 44
The early disc brake 44's ran a small u-joint and a brass washer, the later ones (73 & up) run a larger u-joint & a plastic one, they don't interchange because different inside diameters. I don't think the brass washers are available. You might check with Quad 4x4 (Torque King) They have some NOS stuff.
I had the same issue with some damaged parts & ended up switching axle shafts to the larger u-joints for better parts availability.
B. W. is offline   Reply With Quote
Old 06-25-2018, 09:22 PM   #4
Miller230
Re: 72 k20 Dana 44
BW thanks for the info... I searched torque king and found the kit with the plastic washer but they also sell the bronze washer. The kit says itís for 73 and up but I cross referenced the bearing that it comes with it and thatís at least the same one for my 72. So I am going to give it a try and replace the plastic washer with the bronze one
Old 06-29-2018, 07:28 AM   #5
Re: 72 k20 Dana 44
I see that bronze spacer misplaced more than correct. At least the times I have had someone else work on my stuff. First thing other than visual damage I look for when hubs won't engage. I see them put to the outside at the lockout end.
'67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi...'The 67' (project)
'72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok...'The 72'
"Don't call me a rough cut country gentleman. I'm just a redneck"
R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
