07-22-2018, 04:34 PM | #1 |
Manual to automatic steering column?
Can you covert a manual to an automatic easily? I currently have a manual, 3 on the tree in the truck with a TH350 transmission. I have a complete donar automatic steering column I can use. Just wondering if you have to replace the complete steeing column?
07-22-2018, 05:07 PM | #2 |
Re: Manual to automatic steering column?
if the trucks are the same vintage then just unbolt and swap the whole unit .
make sure your steering shaft end at the column is the same style . early was splined the rest are D-shaft style . then check wipers on dash or column . otherwise bolt it in and go basicly. my info for 73-87 square body .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. Last edited by sweetk30; 07-23-2018 at 07:53 AM. |
07-22-2018, 11:19 PM | #3 |
60-66 Nut
What year of truck and what year of steering column?
07-23-2018, 06:52 AM | #4 |
The truck is a 69 and unsure year of automatic column. It came with truck. They appear to be identical at bolt up point. I was just wondering if you could swap a few parts and convert them without taking the hole thing out?
07-23-2018, 09:48 AM | #5 |
Active Member
If you're trying to maintain the stock look, and if at all possible, the best solution is to look for a complete steering column of the same vintage truck.
Here's a writeup on the same subject: http://www.trucktrend.com/how-to/int...er-conversion/ This is a basic installation and doesn't cover the rest of the parts that you may need or the adjustments such as shift indicator, neutral/park switch and reverse lights.
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
07-23-2018, 11:47 PM | #6 |
60-66 Nut
Without knowing what year the columns is it is impossible to say. But assuming the column is a '69-'72, I would think it would be much easier to change the entire column rather than disassemble both columns and reassemble one inside the truck.
07-24-2018, 09:25 AM | #7 |
The info I am getting is swap the complete columns. Thanks.
Thread Tools | |
Display Modes | |
