02-15-2018, 08:22 PM | #1 |
Sm465
I've got a sm465 won't go into any except low and first. When I pull the shifter out the spring loaded plunger won't go all the way in to let the shifter go to another rail. Any suggestions?
Posted via Mobile Device |
02-15-2018, 09:33 PM | #2 |
Post Whore
Re: Sm465
have you checked to see if the shifter rails are lined up...in neutral? have you had the top off the trans?
02-16-2018, 01:51 AM | #3 |
Re: Sm465
Flash light and a decent sized screwdriver. Pull the stick and look into the hole
02-16-2018, 07:49 PM | #4 | |
02-16-2018, 07:52 PM | #5 | |
02-16-2018, 09:14 PM | #6 |
Post Whore
Re: Sm465
read down to post 9 in this and see if this is what your experiencing....http://67-72chevytrucks.com/vboard/s...d.php?t=322025
02-17-2018, 06:45 AM | #7 |
Re: Sm465
just fixed this on an '89 square body v30 I have. basically I cut the trans tunnel, used both hands to jerk the gear shifter over into reverse (half way into reverse to be able to pull the tranny top off).
had to put a couple of E-clips onto the plunger shaft. All fixed for basically free, just a pain in the butt |
02-18-2018, 12:20 AM | #8 | |
02-18-2018, 12:21 AM | #9 | |
02-18-2018, 12:21 AM | #10 |
Re: Sm465
Thanks gonna try it when the weather will let me
02-18-2018, 08:34 AM | #11 |
Post Whore
Re: Sm465
at least you now know what's wrong. ..got some work ahead of you now...
