Old 10-31-2001, 10:51 AM   #1
BW71
Post Homemade tracking bar?
Put new bushings in my track bar and an old sleeve didn't come out so took it to a shop, problem solved. The guy says did you make that track bar? I told him no but it does look homemade. Heres a description: The eyes are the right size and have about two inches of 1/2 inch bar stock before it run inside the main bar but the main bar is about an inch thick with holes drilled in it and spot welded to the smaller bar running inside it.It's got some really crappy welds on it.
It fits and seems to work but just wondering if thats how they are supposed to be
71 C-10 custom Deluxe
Leavenworth, Kansas
BW71 is offline   Reply With Quote
Old 10-31-2001, 12:04 PM   #2
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
Post
the stock ones have some crapppy welds on um
My Truck pictures
www.xframeimpala.com
68 4x4 short fleetside 327 CH465 edelbrock intake and carb MSD distributor its the "SHAGROLET"
56 big window short stepside 235 dual 1 brls
64ImpalaSS 327
70 C10 LWB fleetside custom/10 350/TH350
IM me on aol SN= SHAGROLET
68SWB4x4 is offline   Reply With Quote
Old 10-31-2001, 01:33 PM   #3
rustfree
Post
sounds like a previous owner bent the original bar (not that hard to do) so cut out the bent section and did what you now have. You may not be centered between the frame rails now! The stock bar is 1 piece bar stock welded to the eyelets. Check out an after market adjustable bar (CPP, ECE, Wes, GMCPaul, etc.) for a heavy duty replacement.
72 swb cheyenne super 350/350
69 cst20 BB longhorn
Warren, OR
rustfree is offline   Reply With Quote
Old 10-31-2001, 05:54 PM   #4
BW71
Post
The bed doesn't seem crooked, but I have noticed that it sticks out a bit on the drivers side behind the cab. about 3/4 of an inch. How would I know if the whole bed isn't centered? I think previous owner took it off once cause there are no bed pads under it.
Leavenworth, Kansas
Old 11-01-2001, 01:39 PM   #5
rustfree
Post
This is assuming you have a coil spring rear as leaves self center the rear wheels...
didn't mean that the bed would be off set. The wheels/axle could be left or right of center line of the frame rails. Measure from brake drum to same spot on frame on both sides to see whether both sides measure the same
Warren, OR
Old 11-01-2001, 03:41 PM   #6
BW71
Post
Rustfree.. .Thanks. I see what your talking about, I should have been able to figure that one out. Oh well thats what this board is for advice and second opinions 500 or so heads are better than one...
Leavenworth, Kansas
