Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 11-26-2018, 01:11 AM   #1
chris989
1989 c6000 GCWR
Hello,
I have been searching for days, called the DOT and still have no answer about the weight ratings for this truck.
I did not see a sticker on the door when i looked at the truck and just did not think it would be so hard to find out the numbers.
the VIN is 1gdc6d1b4kv508010. it is a 1989 C6000 dump truck. I need to haul a ~15-17k pintle hitch trailer legally.
GM heritage support said 10K but that can't be right????
thanks,
Chris
chris989 is offline   Reply With Quote
Old 11-26-2018, 05:19 PM   #2
jdl71
jdl71's Avatar
Re: 1989 c6000 GCWR
I was under the impression that as long as you had enough license (ie plates;26,000, 54,000, etc) to cover your total weight you would be ok as far as DOT is concerned. Is that not correct?
Psalm 23
64 C10
66 K20
jdl71 is offline   Reply With Quote
Old 11-26-2018, 08:16 PM   #3
sweetk30
sweetk30's Avatar
Re: 1989 c6000 GCWR
what little i know about playing with dot . . . try that and see just how fast your wallet goes from full to empty with fines .
in most states you can not reg above what it was max for from the factory . then what your trailer is max for . then add up empty weight of both and this is how much you should be able to haul . but dont load the trailer wrong and be over on the truck and under on the trailer cause this will get you a ticket .
i have a nice 88 gmc 7000 i would love to keep but saddly for me non cdl license guy i am i cant drive it with air brakes and dot around here love to play with everyone .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 11-26-2018, 09:34 PM   #4
jdl71
jdl71's Avatar
Re: 1989 c6000 GCWR
I see 3/4 ton trucks here quite often with 24k plates on them. Not saying it’s legal or not but Missouri hands then out. What does one do in the situation the op is in when the gcwr is na?
Psalm 23
64 C10
66 K20
Old 11-26-2018, 10:36 PM   #5
C10 - C90 Bill
C10 - C90 Bill's Avatar
Re: 1989 c6000 GCWR
I ran the VIN Number this morning and one site recognized it, but they wanted $14.95 to see it. Wish I new more about the newer trucks. Have you determined where the GVW Tag should be? Again, not sure about the newer trucks, but the older trucks have a Metal Plate either tack welded or riveted.
'60-'72 Chev/GMC Fan
GMC 9500 Fan
Detroit Diesel Fan
C10 - C90 Bill is offline   Reply With Quote
Old 11-26-2018, 10:45 PM   #6
C10 - C90 Bill
Re: 1989 c6000 GCWR
Here in Virginia, you can drive a truck with Air Brakes as long as the GVW is 26,000 or less, last I checked anyway. As some say you can and others say you can't. But I contacted the DMV directly, twice actually, although years ago.
But evidently even the Law is also unsure about it, lol. Some cops say you can, others say you can't.
If I had one, I was going the copy the info I got from DMV and carry it with me. But although I checked on a few trucks, I never bought one in question. As they are pretty rare. My old truck license ran out when CDL's were implemented back in the early 90's.
I could never understand the big deal about Air Brakes anyway. I started using them when I was 11 years old. I thought they were great. You want to stop, you press on the pedal, lol. I sold my last Air Brake truck back in 1990.
GMC 9500 Fan
Detroit Diesel Fan
Old 11-27-2018, 12:06 AM   #7
Robert1970C20rstbukt
Robert1970C20rstbukt's Avatar
Re: 1989 c6000 GCWR
The decoder I found says that truck has a 14K to 16K GVW with hydraulic brakes, and had a 366 gas engine from the factory. Couldn't find anything about the GCWR.
http://www.73-87chevytrucks.com/tech.../1989truck.pdf
RJD
1984 Chevrolet C30 welding truck 454/SM465
1977 GMC C15 pickup 350/TH350
1970 Chevrolet C20 pickup 350/TH400
1970 Chevrolet K20 Suburban 454/TH350
1969 GMC 8500 478M V6/5 spd winch truck
Robert1970C20rstbukt is offline   Reply With Quote
Old 11-27-2018, 12:57 AM   #8
chris989
Re: 1989 c6000 GCWR
Robert,
Thanks for looking, I am going to call GMC again tomorrow and see if i can find out something.
Chris
