12-27-2016, 09:34 PM | #1 |
Can I remove only the core support and inner fenders?
Will the core support and inner fenders (wheel wells) come out clean when engine is out ?. I want to keep the fenders and grille attached. Just wanted to do some engine bay cleanup while engine is out and specifically sand blast the core support and parts of the wheel wells (especially the surface between the inner and outer fender). I want to be sure this can be done without messing something else up before I start tearing things apart. Thanks.
12-27-2016, 10:22 PM | #2 | |
Re: Can I remove only the core support and inner fenders?
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
12-27-2016, 10:26 PM | #3 |
Thanks! Also, not sure if it makes a difference, but this is on a 1967.
12-27-2016, 10:30 PM | #4 | |
RUBBER DOWN AND HIT THE ROAD!!! 1940 Ford Dlx Coupe 1969 Mach1 |
12-27-2016, 10:40 PM | #5 | |
12-27-2016, 10:43 PM | #6 |
the 67 grill also has that gravel pan at the bottom may get in the way or at least thats bolted to the core support .....i have a 67 nose on my wannabe 71
