Old 09-21-2014, 10:54 PM   #1
63swag
63swag's Avatar
Changing trailing arm crossmember
Can you change to a PB trailing arm crossmember without pulling the cab? Mine will be here tomorrow and was hopeing I could just drive some rivets out and bolt it in. Thanks for the help!
63swag is offline   Reply With Quote
Old 09-22-2014, 12:40 PM   #2
steveb64
Active Member
steveb64's Avatar
Re: Changing trailing arm crossmember
You can, did mine that way.
Biggest trouble I had was drilling the new holes square to the frame on the top. A heavy duty right angle drill motor would help.
steveb64 is offline   Reply With Quote
Old 03-16-2017, 07:29 PM   #3
statenine
statenine's Avatar
Hey guys sorry to bring up this super old thread, but I am curious how you go about drilling out the top rivets when the cab is still on? I want to change my TA crossmember as well but definitely do not want to remove the cab if it isn't 100% required! thx
statenine is offline   Reply With Quote
Old 03-16-2017, 08:29 PM   #4
PGSigns
PGSigns's Avatar
Use an air chisel to take the heads of and then drive them out. .
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 03-16-2017, 08:55 PM   #5
statenine
statenine's Avatar
Jimmy
But can you do that with the cab on? Doesn't seem like a whole lot of room between the top of the frame and the bottom of the cab to do that...
Old 03-18-2017, 10:18 AM   #6
PGSigns
PGSigns's Avatar
You can get to them from the bottom side. It is a real pain to do it with the cab on. If you are not saving the old cross member take and cut it off with a sawsall close to the frame to get it out the way and it eases getting to the rivets with the air chisel.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
