Old 09-13-2017, 01:59 PM   #1
Matt_50
Rear suspension for my 1950
I just got my front suspension installed and now I'm ready for the rear. My front end is now raised, can I simply bolt on a rear axle under rear springs to even height? Is there anything else needed? I thought getting rid of the torque tube meant axle could move around am I wrong?
What about adding a different suspension. Could I, has anyone, used the rear hangers and springs from a c10? Any pics or links to a good thread would be great. I would go ahead and put the c10 springs on but I'm concerned and bout the 1950 3100 having wider rails.
Matt_50 is offline   Reply With Quote
Old 09-13-2017, 03:07 PM   #2
dsraven
Re: Rear suspension for my 1950
if you wanna move the axle you may need to get rid of the torque tube. that means the rear of the trans goes away as well in order to accept a standard slip yoke and open driveshaft.
I have heard guys are using the spring hanger brackets from a ford ranger and/or leaf springs from an S10. dunno for sure though. the spring hanger brackets are available aftermarket. you could try a gm axle but the width will be wrong for your old truck. S10- maybe the closest
Old 09-13-2017, 03:07 PM   #3
dsraven
whaddya got for a front end and how much did it raise?
Old 09-13-2017, 03:12 PM   #4
Matt_50
Front end is from c10. I know... a little wide and will stick out or need offset wheels. I've seen a couple done this way and it looks good to me. Raised like 4 inches so I might need to lower it. New engine and trans will be a stock 350/350.
Old 09-13-2017, 04:56 PM   #5
Matt_50
Is it popular to have suspension brackets for leafsprings on the outside of frame for these trucks? How about having axle under springs like my c10 is?
