Old 11-24-2017, 01:12 AM   #1
1971'Burb
SM465 PTO options?
The truck is a 1985 C60 2WD. Equipped with 5.7 and the 4 speed (SM465?) - 2 speed rear end. What are the PTO options for this transmission? Some part numbers will be appreciated.
Crawl, walk, run, fly... what's next?
1971'Burb is offline   Reply With Quote
Old 11-24-2017, 10:15 AM   #2
A1971Blazer
A1971Blazer's Avatar
Re: SM465 PTO options?
Chelsea is the only one I've ever heard of google "Chelsea PTO"....ebay will probably be your best bet to find a good used one....
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 11-24-2017, 12:02 PM   #3
1971'Burb
Thumbs up Re: SM465 PTO options?
Great! Thanks.
Old 11-24-2017, 01:21 PM   #4
kwmech
Call these guys, they can build whatever you want. Right hand, left hand, front, back, etc
http://www.sixstates.com/products/products.jsp
Old 11-24-2017, 02:30 PM   #5
1971'Burb
Smile Re: SM465 PTO options?
Nice!
After a few hours of research, I've found some information here.
Some one suggests the 340 and 352 series Chelsea PTO should mesh just fine.
Old 11-26-2017, 10:15 AM   #6
Tiger Joe
Just start checking junk yards or even local clist. Tons of old square body’s floating around with ptos left on them.
What setup are you looking for? Lots of the early setups were ptos that drove a small Driveshaft. Later one seems to be direct pto mounted hydraulic pumps.
Tiger Joe is offline   Reply With Quote
Old 11-26-2017, 12:09 PM   #7
1971'Burb
I'm hoping to find one which I can use for a winch set up and to run a brush hog I can drag around with my old work truck.
Old 11-27-2017, 02:52 PM   #8
D.PASSMORE
One of the First
D.PASSMORE's Avatar
If the PTO is used on a rear apparatus. It will probably need a least a 8 in straight shaft coming out of the PTO case. Most attaching shaft yokes have clearance issues with the transmission case if the output shaft is shorter than that.
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
'71 SWB K/10 CUSTOM DELUXE (Chili)
'72 BLAZER K/5 Muscle Truck (Mule)
'72 LWB K/20 CHEYENNE (Blackie)
D.PASSMORE is offline   Reply With Quote
Old 11-27-2017, 03:50 PM   #9
1971'Burb
I'm leaning towards the 352 series PTO. Thanks for the info!
Hoping I have no major issues at 540rpm. Still doing research. Looks like I'll end up with about 9 feet long shaft under my single cab dually.
Old 11-29-2017, 02:15 AM   #10
kwmech
You'll probably need at least 2 pillow blocks with a shaft that long
Old 11-29-2017, 08:15 AM   #11
A1971Blazer
try to keep the drive shaft to the pump as short as possible and simply use longer hydraulic lines...that way you won't need pillar block bearings and all the excess moving parts..just plumb the high-pressure lines to whatever you intend to power.....a couple of valves and you're all set...
1967 C10 Step side
1968 C10 Step side
Old 11-29-2017, 10:41 AM   #12
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Your going to have a keyed stem shaft coming out of PTO unit, make sure it clears transmission case. Then you will attach the longer shaft to the PTO and hydraulic pump. That's when you get into yokes, pillar bearings, angles, etc...
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
