04-03-2018, 09:58 PM | #1 |
High Rise Intake Edelbrock 7101
Being offered a high rise intake. Edelbrock 7101. My motor is completely rebuilt with new stock parts. Maybe 10k on it. I have a 650 Holley on it now. Can anyone tell me if this will be compatible as a “bolt on addition” Or will I need to do some other work on it to have the truck run decent? Runs excellent now. I do want to add hp, would this be a good piece to add?
04-03-2018, 10:05 PM | #2 | |
Re: High Rise Intake Edelbrock 7101
https://www.summitracing.com/parts/e...SAAEgIoYfD_BwE
'81 K20 Silverado , '99 Dodge Cummins 4x4, '05 Dodge Cummins 4x4, Pinstriping-Lettering-Specialty Painting |
04-04-2018, 12:50 AM | #3 |
I did look the part up. More curious if I can just add it and be done or if I’m going to have to buy more parts to make it functional
04-04-2018, 07:51 AM | #4 |
nothing is ever bolt on . . . .
and thats more a mid to upper end intake . to get upper power you loose a little lower end . . . and vise versa . our big heavy trucks need lower end and torque to get them rolling . good old saying : torque gets you rolling and horse power keeps you rolling .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
04-04-2018, 11:25 PM | #5 |
Sounds like at this point it not a good addition. I truly just don’t know what works and what does
04-04-2018, 11:41 PM | #6 |
If your block is 86 or older then it will "bolt on", but like mentioned before it probably wouldn't benefit your stock engine very much. A 2701 would be a better choice.
80 C10 SWB Step Side - 350 w/ vortec heads, TH350, 12-bolt 3.73 |
04-05-2018, 12:54 AM | #7 |
Performer RPM is an excellent manifold, but not my first choice for a stock 350 rebuild. Plenum volume and runner cross section are both a bit on the large side for that application. You'll notice a slight decrease in off-idle torque compared to either the stock iron or Performer (2101) manifold, but possibly slightly more power in the mid-upper rpm ranges.
With stock internals, the stock iron unit is pretty tough to beat, but a 2101 Performer can give it a little bump in the midrange without sacrificing power down low. |
04-05-2018, 07:09 PM | #8 | |
