10-24-2018, 03:13 PM | #1 |
crew cab showcase
just wanted to see everyone's pics of their crewcabs. might be buying a ccsb 4x4 next week
10-24-2018, 03:55 PM | #2 |
Re: crew cab showcase
It's a work in progress, but here it is and my build thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=691478
76/77/78 Cheyenne 1997 K3500 454 soon to be 496 |
10-24-2018, 04:26 PM | #3 |
very nice
10-24-2018, 07:58 PM | #4 |
Who Me?
Subscribed!!
Steve 1997 Tahoe LT 4D 2WD (DD) 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
10-26-2018, 10:42 AM | #5 |
Not much to see yet (Project: Spot). Biggest visual changes so far since purchase:
* Swapping damaged sheet metal w/wrecking yard replacements (SWB bed, rear pass door) * Swapping out the work-damaged tail gate w/a new/take-off gate from C-list * Yanking the stained STINKY carpet * Swapping the 60/40 front bench for buckets/console from a Tahoe * Getting all new exterior lighting plastics + F/R smooth bumpers (no impact strips) I have accumulated all the parts & will start maintenance related mods soon: * Front end rebuild w/Moog parts, Belltech drop spindles, & Bilstiens. * Belltech rear flip + c-notches, new axle seals, rebuild brakes, & Bilstiens. * New wheels/tires in staggered widths. Eventually it will get 2-linked w/bags. I have the parts just not the time to get it done (like I want) right away.
10-26-2018, 12:27 PM | #6 |
Here is my 99 C2500 short bed thanks to hurricane Michael depositing my neighbor's tree on it. I've talked with my insurance but told them I wasn't ready to have it looked at cause I still need it to move debris. I'm sure it will be totaled and I'll have to fight for its actual worth. I'd love just to replace it but I don't seem to see many 1999/2000 C/K2500 short beds for sale. If it doesn't violate the board rules, I'd be curious to know what you paid for your truck SCOTI.
FOUNDING MEMBER OF THE DRUM BRAKE CLUB Second Owner 70 C-10 Second Owner 93 GMC C1500 Third Owner 99 C2500 Crew Cab Short Bed |
10-26-2018, 04:27 PM | #7 | |
I'm pretty sure the previous owner bought it for an easy flip after swapping in a fresh 5.7l long-block but was in over his head w/all the electronics of the later model (he'd done several older GM cars/trucks; this was the newest he said he'd messed with). You had to pop the hood & use a remote starting switch + jump it off just to get it started. Once running, it had zero power & couldn't get out of it's own way so there was no real way to determine if it was a good or bad deal drivetrain wise (it couldn't/wouldn't go fast enough to get on the highway to test the OD trans ). I gambled on it. After sorting through things (grounds, wiring, battery, o2 sensors, more grounds, & fuel INJ. system), it's been pretty a decent truck so far (I've only had it since June 2017). The 1st time I was able to get it on the highway @ speed, it was apparent the front end needed attention. In the end, I got a 'rare' factory 130k mile CCswb 5.7l/4l80e combo w/a fresh, zero miles 5.7 for what the 250k mile, single cab, swb, 4.3/5spd, no-carpet truck I was driving sold for.
10-29-2018, 05:35 AM | #8 |
This is my old girl, had her for 12 years so far, hopefully many more.
11-24-2018, 02:15 PM | #9 |
Here's mine, new to me and changing almost every other day.
11-24-2018, 06:31 PM | #10 |
Nice!
11-24-2018, 06:57 PM | #11 |
There are a couple of those for sale right out the road from me .
11-24-2018, 08:30 PM | #12 |
At the body shop.
117k familia truckster
454 4L80 4.10 And the rest of my junk too.
" That didnt make it any newer " " Dont antique the equipment " |
12-11-2018, 06:29 PM | #13 |
Well everyone here is my crew cab
Posted via Mobile Device |
12-11-2018, 07:06 PM | #14 |
Awesome! Engine and trans combo?
12-11-2018, 07:27 PM | #15 |
it had a 454 with 4l80e but took it out, I'm wanting to either ls swap or diesel swap it. the truck has a 6 inch pro comp lift with an 2 inch body lift. clears 40s easy. no rust except the passenger front door has a big dent and its rusted there
12-11-2018, 08:16 PM | #16 |
Looks like the rear end was swapped too. Should have came with a full floater.
12-11-2018, 09:26 PM | #17 |
im no expert on suspension systems, can you elaborate on the full floating axle please?
12-12-2018, 08:57 AM | #18 |
the axle shafts can be removed without pulling the dif cover to remove C clips.,
12-28-2018, 10:41 PM | #19 |
One day.....
My crew...
DZL1. Bertha build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=733306 '72 C10 short bed. Bessie (traded) '93 C3500 CC Dually. Bertha (traded) ‘96 C1500 ECSB. Black Beauty '89 C1500 RCSB LS swap. Black Bean '06 Silverado CCSB Ghost (Wifes Truck) '12 GMC Terrain V6. Titanium Bling (Wife’s Daily) ‘14 Chevrolet Cruze. Raspberry (Daughters Ride) '99 Jeep Wrangler. Road Hog (Sons Ride) |
12-29-2018, 07:59 AM | #20 |
Here’s mine. I’m putting in a water pump this morning.
12-29-2018, 09:54 AM | #21 | |
12-29-2018, 10:02 AM | #22 | |
One day.....
12-29-2018, 02:58 PM | #23 |
It looks good in pictures, but it doesn't look that good up close. I'll be working on it in the spring. I have a rust free bed, 4 doors, a hood, and a left front fender to replace.
I love this money pit. So far I've but GMT800 brakes on it, change the interior from red leather to tan cloth, installed factory clearance lights, replaced the engine, trans, rear axle, and many other maintenance items. |
01-14-2019, 05:01 PM | #24 |
01-15-2019, 12:39 PM | #25 | |
