Old 04-02-2014, 10:07 PM   #1
zpeters18
TH400 to SM465
hello. i recently purchased a 1987 gmc 2500. it has the turbo 400 trans and np208 transfer case. i am hoping to do a manual swap on it to a sm465 trans. what all would i need to do this? thanks
zpeters18 is offline   Reply With Quote
Old 04-02-2014, 10:13 PM   #2
Redcap
Re: TH400 to SM465
Besides the trans/transfer case, you'll need to decide if you want a mech or juice clutch...the pedal kits are different. You'll also need a flywheel, clutch, pedal box, floor hump (or cut yours), linkage or hydro components. You'll also likely need some driveshaft work done. Probably some stuff I've forgotten too.
'77 K35 - 454, SM465/NP205, 4.56 D60/14bFF
Redcap is offline   Reply With Quote
Old 04-02-2014, 10:19 PM   #3
zpeters18
Re: TH400 to SM465
so not necessarily 'hard' , just finding all the parts to do it
Old 04-03-2014, 09:04 AM   #4
Rollo McFlurry
Re: TH400 to SM465
Correct. It's easiest to have a donor truck. I would look for a transmission mated to an np205 with a fixed rear yoke. The slip yoke versions are also acceptable if you want less driveline hassle.
Rollo McFlurry is offline   Reply With Quote
Old 04-03-2014, 03:57 PM   #5
Wrenchbender Ret
Re: TH400 to SM465
You will need a bell housing to go with the SM465. It has a larger center hole then the 3 speeds or earlier models.
Wrenchbender Ret is offline   Reply With Quote
Old 04-03-2014, 05:54 PM   #6
zpeters18
Re: TH400 to SM465
what would be easier? a manual or hydraulic clutch?
1987, gmc 2500, sm465, th400
Copyright ©2000 - 2020, vBulletin Solutions Inc.
Copyright 1997-2020 67-72chevytrucks.com
