Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 05-23-2020, 11:28 AM   #1
RustyBucket
RustyBucket's Avatar
0ld 4 post lift AWFUL NOISE!!!
I've had a 4 post lift for 13yrs.. It's not a "brand name"... chinese made I guess. Runs on 110v, I've had my '02 C.Cab on it a couple of times but usually my old trucks. I had some health problems and didn't use it much for 6-8 mos. It works ok, but it's making the most AWFUL LOUD BUZZING NOISE when it's lifting. I've lubed every pulley and contact point I can see on it. The fluid level is ok, no leaks & it's filled with the recommended hyd. oil. I wiped the shaft on the Hyd. cyl. with hyd. oil. Sounds like the noise is coming from the BIG hydraulic cylinder under the driver side ramp. Apparently the ram is leaking pressure slightly.. it makes an occasional popping noise if it's not resting on the locks. Wish I could stop the noise.
Dad always said, "Son, WISH IN ONE HAND, and ......."
'71 GMC 1500 SUPER CUSTOM short/step, orig. dk. blue, 350/700r, ps,pb, A/C
'72 Blazer 2wd, ochre & white, 454, tremecTKO 500 5spd. ps, pb, A/C, tilt
'66 Plymouth Belvedere City of Miami cop car clone. Donated to the Miami PBA Museum
'70 Nova 406"sb, 13.5-1, solid roller, Brodix, p.glide/t.brake, back halved, 9" Ford, spool 4.88, cage,ladder bar/coilover, 10.5 tire....... SOLD!!
'67 C10 short/step side mount spare -- shop ornament, needs resto.... SOLD!!
'72 Jimmy 2wd, 350/350, ps, pb, fun driver, lots of bondo & a shiny red paint job..... SOLD!!
'69 Nova 350, 4spd, A/C, ps, p.b, needs resto...SOLD!!
RustyBucket is online now   Reply With Quote
Old 05-23-2020, 01:34 PM   #2
mongocanfly
mongocanfly's Avatar
Re: 0ld 4 post lift AWFUL NOISE!!!
Does it leak down after a lift?...if you think the cylinder is bypassing it may need a rebuild..
Mongo...aka Greg
2013 GMC Z71..daily driver
Copyright ©2000 - 2020, vBulletin Solutions Inc.
Copyright 1997-2020 67-72chevytrucks.com
