Old 10-09-2010, 03:03 AM   #1
Youngbuck7072
Youngbuck7072's Avatar
What is a 383 stroker and how do you build one?
just want to know what makes a 383 stroker a 383 stroker. i know that its just a 350 thats been stroked, but what does that mean? what is the HP and torque gain? and how do you build one and what specs do you need. pictures of your 383 would be great too.
........................ __
............._______|__\____
............|_({})______({})]
................(O)..........(O)
Youngbuck7072 is offline   Reply With Quote
Old 10-09-2010, 03:33 AM   #2
69 longhorn
Re: What is a 383 stroker and how do you build one?
Well, old school was basically a .030 over 350 with a 400 sb crank with the mains turned down to fit. This old school stroker also used the shorter,400 sb rods. Today, there many aftermarket 383 cranks that are as cheap as grinding the old 400 crank, & most kits use the longer 5.7(350 rod). this does require some clearancing in the lower end of the block, & on the rod bolts , for cam clearance. Also , these run a 400 sb balancer & flexplate, & a shelf stroker piston(special pin height). by going with a 3 3/4 " stroke, vs the stock 3.48 stoke on a 350 , you add cubes & tork. A properly setup 383 will pull a lot more tork than a 350, & @ a much lower rpm range. As far as specs.....its just depends on what you want(daily dr,or weekend toy). crazyAL
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 10-09-2010, 11:53 AM   #3
Youngbuck7072
well, i have seen vids on youtube of them and they look sick as hell, i kinda want a dailey driver that can get down when needed
Old 10-09-2010, 12:19 PM   #4
GMCBubba
GMCBubba's Avatar
just so we're all on the same page... a 383 LOOKS no different than a 350. they are the SAME block. all changes are internal. if what you see are people with TALL valve covers, that is only needed to accommodate certain types of rockers and stud girdles. nothing to do with engine size.
1969 GMC 3/4 ton, 307, 4-speed NP435GL, DANA 60, 4.10, HD rear leafs, manual everything, leaking oil and water. Now rocking 383, NV4500, power steering, power brakes. Finally undergoing restoration.
GMCBubba is offline   Reply With Quote
Old 10-09-2010, 12:26 PM   #5
Youngbuck7072
no. i mean like, they sound sick and they LOOK like they can get down
Old 10-09-2010, 03:45 PM   #6
pockets
pockets's Avatar
the nice thing about today is you don't have to source a 400 crank, flexplate and all that. you can get complete kits that include all new parts. I got mine from Summit Racing which is an Eagle assembly that includes the flexplate, balancer and everything else.
Project Bad Karma
pockets is offline   Reply With Quote
Old 10-09-2010, 04:27 PM   #7
BarryB
BarryB's Avatar
I had my motor work done for a 383 long time ago, block and all the parts are still sitting on the shelve waiting and waiting. After saying all, This was before the kits were really readily available. If I had known about a kit with all the right parts already, that is the route I would go. I haven't heard any bad things about eagle stroker kits. there reasonablly priced also.you get it , and it's ready to bolt in, granted you have the machine work already done to the block. it will have to be bored .030 over bore and clearanced for the larger stroke.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
Old 10-09-2010, 04:37 PM   #8
GMCBubba
GMCBubba's Avatar
well, that's what i'm hoping for. bought a used stroker from a board member and am VERY excited about getting it all in. still accumulating lots of parts to finish up the swap. now all that's left is to decide on a new transmission.
from all that i've read it should be the ideal truck small block. cheaper small block parts/accessories with tons of low end torque. i'm not making a race motor, so low RPM power and street driveability are key.
Old 10-09-2010, 06:51 PM   #9
Schralper
Schralper's Avatar
what is a 383? Expensive if done right, namely cyl heads
how do you build one? pay a good machine shop/ machinist $$ to do it
Schralper is offline   Reply With Quote
Old 10-09-2010, 07:23 PM   #10
Youngbuck7072
where in oregon do you live schrapler?
Old 10-10-2010, 12:18 AM   #11
Schralper
Schralper's Avatar
pm'd ya
anywho might wanna check w/ southworth off like 6th & garfield?
i've been happy w/ their work.
my bro sez Drummond machine in Pleasant hill is pretty good, i'm gonna try'em w/ redoin 1, yes 1 of, my current 383's. wanna get it machined 2 bolt to 4 bolt splayed for turbo.
FYI - seriously there is no way to do a $2-3000 383. you'd be better building a stout 355. i've tried & $4K is the least I could reasonably spend. My newest is over $6K for solid 550ish HP. Sure stock heads, up to 350HP?, will work but you'd be shooting yourself in the foot, yes the right foot, @ that point.
my .03 (yep .01 better than .02)
Old 10-10-2010, 12:24 AM   #12
Youngbuck7072
Originally Posted by Schralper View Post
pm'd ya
cant wait to see it in a rig after its done
Old 10-10-2010, 12:32 AM   #13
Youngbuck7072
and this might be a stupid question, but can you 383'erize a 350 four bolt main
Old 10-10-2010, 01:36 AM   #14
ERASER5
ERASER5's Avatar
Yes.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 10-10-2010, 04:21 PM   #15
GRX
GRX's Avatar
Of course. Not much advantage though since the outer bolts in a stock block aren't splayed (angled outward).
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed.
GRX is offline   Reply With Quote
Old 10-10-2010, 07:31 PM   #16
llowlife
Youngbuck, if you are going to build a stroker motor I strongly recommend you find someone with good experience to help you. No offense intended because we all had to start somewhere but according to your signature getting this wrong could cost you several thousand dollars. A rod or block interference problem will get very ugly very quickly. Not to mention what a rod bolt head will do to a camshaft or too small a valve interface.etc, etc,etc. there is a fair amount to check and remember and recheck and grind and remeasure and etc. There are kits out there I believe (never used one) that can simplify the process but everything still needs to be checked as if anything goes wrong it is your fault. I am not trying to talk you out of anything but a 350 would be a good first motor to build. Get the book "How to rebuild your smallblock chevy" by David Vizard and read it...then read it again. I built my first race motor over 30 years ago and I will still sit down and read this book from time to time. Also "Power secrets" by Smokey Yunick is an excellent book. If you have questions please ask.
In the beginning of a change, the patriot is a scarce man, brave hated and scorned. When his cause succeeds however, the timid join him , for then it costs nothing to be a patriot.
I am a revolutionary...so my son can be a farmer...so his son can be a poet. If there must be trouble, let it be in my day, so my child may have peace...
72 short step w/ 388 /4l80e/ and 3.08 gears.
llowlife is offline   Reply With Quote
Old 10-10-2010, 07:58 PM   #17
Youngbuck7072
thanks low life, and yah, there is no way i would attempt to build a 383 at this time in my life. The motor thats in my frankenchevy is a brand new crate motor so it doesnt need to be rebuilt , but i wouldnt mind finding a cheep 400 or 350 and rebuilding it, just to see if i can. the only problem is that i don't have the facility to do it,......yet. another cool one would be a 396, but a cheap one is hard to find in my area(most of them are in camaroes).oh, and if you have an extra copy of either one of those books, can i have it??
Old 10-10-2010, 11:23 PM   #18
llowlife
I may have one, eventually I may run across it and i will remember our conversation.
Old 10-10-2010, 11:42 PM   #19
Youngbuck7072
sweet, thanks man
Old 10-11-2010, 01:14 AM   #20
Ticker
It's absolutely possible to do a low-budget 383 and if you need to replace and/or machine the crank at overhaul, it's just about a wash with the cost of doing a 355.
Ticker is offline   Reply With Quote
Old 10-11-2010, 08:41 AM   #21
skeeterbug
skeeterbug's Avatar
i agree w/ u schralper on the price of a stout 383 build, i am currently having one built, already over 5k in it. by the time its all said and done my motor is going to run me over 6g's, but im cool w/ that for an all forged aluminum headed roller motor pushin over 525 hp. good luck on you build hope it all works out for the best for ya.
'71 LWB c10-"WORK" in progress
385 ci 4 bolt (4.040 bore), scat 6.0" forged h beams,scat forged crank 3.750, speed pro 5cc flat top, clevite bearings, .039 head gaskets,comp xr288hr 110* 288/294adv. 236/242@.50 555/576 lift, pbm hyd roller lifters, chad spiers 215cc imp. heads , comp 1.6 roler rockers, comp magnum push rods, edelbrock victor jr. single plane intake p&p (1206 gasket matched), quickfuel 750R DP , th 350 trans, 5.14 gear, 3000 stall
2012 best 1/8- 7.70 @ 87mph 1.70 60' (lil better)
2013 best 7.39
2014 best-7.38
New for 2013-strange rear coilovers, headman 1-3/4 headers, 5.13 r&p, .060 aluminum bed floor, 15x14 holeshots w/ 31x18.5 hoosier dot pro's, 15x4 holeshots w/ 26x5.5 m/t skinnies and 200+#'s in body weight loss & 6 point cage
skeeterbug is offline   Reply With Quote
Old 10-11-2010, 09:18 AM   #22
Ticker
It's just not that hard to build 383s any more. There's no need to turn down a 400 crank or use spacer bearings given the ready availability and low price of aftermarket cast cranks. Stroker-clearance rods are also inexpensive - often right in there with having stock rods resized. Clearance for the rotating assembly is a light touch with the right rods and many shops do it for free or very low cost as they know exactly where to do it.
I've built dozens of low-buck 383s with cast cranks and stroker-clearanced rods for about the same price of a comperable 355. As noted, the price of the crank is a wash if you have to buy or turn the crank, the rods are about a wash, the rest of the rotating ass'y is the same price. Generally you're looking at maybe $200 to clearance the block.
For a mild 383, mondo heads are also not required and Vortecs will feed a 383 up to around 400 HP or so. If you're overhauling an SBC...you should do a 383 - no question.
The overhaul book referenced is an older version, and a good one:
Amazon.com: How to Rebuild Your Small-Block Chevy... Amazon.com: How to Rebuild Your Small-Block Chevy...
There's another book I recommend these days that's far more detailed and up to date. It's not perfect, but it's really good
Amazon.com: How to Rebuild the Small-Block... Amazon.com: How to Rebuild the Small-Block...
Old 10-12-2010, 05:43 PM   #23
Wasted Income
Boosted Member
Wasted Income's Avatar
A 383 stroker is something that was rendered outdated with the advent of the LSx motors
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2016 Ford Explorer Sport - Twin Turbskis
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 10-12-2010, 05:58 PM   #24
pockets
pockets's Avatar
come on, you know that's nonsense
a 1st gen SBC is still cheaper to build and install than LS-based motors in most cases. Not that I wouldn't mind having an LS motor...
Project Bad Karma
Old 10-12-2010, 06:14 PM   #25
Wasted Income
Boosted Member
Stirring the pot
Turbo diesel
