Old 08-21-2018, 10:51 AM   #26
JHarman69c10
Re: Husbands-*1969 C10 manual 3speed - camper special project
Will definitely snag a bunch of pictures when he gets home. Guy told him it had a 292.
It seems pretty good on gas so far.
And he doesn't need 2 go over 55... Man has a led foot and tends 2 get speeding tickets. Lol
JHarman69c10 is offline   Reply With Quote
Old 08-21-2018, 01:27 PM   #27
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
This website is a great place to spend your time on the net. You should be able to fuind out everything you and "Grumpy" need to know to get the truck to safe driving condition. As has been stated those trailing arms should be your first priority and have to go.. You can buy new ones but you can probably pick up and original good used set in the parts section of this website.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 08-21-2018, 02:37 PM   #28
JHarman69c10
So only the driver side trailing arm is Swiss cheese. The passenger side still seems solid.
Old 08-21-2018, 04:40 PM   #29
VWNate1
VWNate1's Avatar
Post Safety & 6 Bangers
FWIW, the 3/4 ton trailing arms are the same thing but beefed up & welded to prevent flexing, replacing them both with good used ones from a fellow member here is wise, the bushings are not fun to change but it's a do it once and be done deal .
The i6 engines will easily go *much* faster than one should drive them so be aware if it seems to use too much oil or leaks a lot, his lead foot might be the problem, not the engine .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline   Reply With Quote
Old 08-22-2018, 12:12 PM   #30
bill3rail
bill3rail's Avatar
Originally Posted by JHarman69c10 View Post
1.) Hazzard knob... Pretty sure it's busted off in there (see picture) what do we have to do to get it out and make hazzards function again?
2.) Heater core and all components, previous owner disconnected everything instead of fixing the problem
3.) Need a new steering wheel and bearing (previous owner tried to pull the steering wheel without an actual puller .. looks like he took a hammer and chisel to it) so the wheel on there is not original nor does it fit properly.. I don't want to break the bank on a steering wheel so ideas?
4.) White cloudy ring around the windshield? Wtf is it and why? and can I make it go away!?
5.) Original Oil bath air cleaner ?.. like original looks like a tiny UFO.
6.) Parking break lines
7.) converting drum breaks to disc breaks
8.) New dash pad
9.) Suspension... Coil vs leaf
Real nice truck. Definitely looks to be a 250.
You should call every 67-72 Chevy truck parts company and request a catalog. There are others who do not print catalogs and have web sites, so save every one of them, as some offer parts not available elsewhere.
Manes Truck parts offers some good used parts which are not available aftermarket.
Judging from where you are located, you should be able to find junk yards and collect a bunch of needed parts there. Pick-A-Parts are your best bet for cost.
Heater Core, check Summit they sell a Copper/Brass one.
Brake lines can be purchased locally and bent to fit just get a pipe bender to prevent kinks.
Oil bath air cleaner is Ok if that is all you have. I would change it over to a dry element.
Drum to disc brakes is readily done. Two routes to take would be
A) Buy a complete kit for over $1,000.
B) Buy all used parts and convert it.
I took route A. Easier and I had the cash on hand when I bought the parts.
Suspension: You have coil and trailing arm so I would stick with it but look for replacement arms which are not rotted through.
Ok let me start off by saying hi I'm Lindsay... Aka wife of grumpy old man that just got a grumpy old truck.
Originally Posted by Grumpy old man View Post
Let's make it perfectly clear ,NOT the wife of this Grumpy old man !
That was cleared up quickly! When I first read her post I thought he moved from God's Country directly into Satan's Outhouse! Then again, my part of NY would be the outhouse her area is much nicer!
1970 C10 8' Fleetside, L6 250, 3 on the Tree.
The most basic of pickup trucks!
bill3rail is offline   Reply With Quote
Old 08-23-2018, 08:07 AM   #31
bill3rail
bill3rail's Avatar
Here is a set of trailing arms for sale.
http://67-72chevytrucks.com/vboard/s...d.php?t=769923
Old 08-25-2018, 12:45 PM   #32
JHarman69c10
How the frick do I tell what engine this thing has? He was told 292 but everywhere I look online to research this truck says they usually had a 250. I tried reading all the numbers on the engine but some seem worn off and hard to read.
Old 08-25-2018, 01:12 PM   #33
geezer#99
geezer#99's Avatar
Measure the side covers or see where the fuel pump is.
Covers are 6” tall on 292.
Covers are 4”on 250.
Fuel pump behind motor mount is 292.
Pump in front is 250.
geezer#99 is online now   Reply With Quote
Old 08-25-2018, 01:37 PM   #34
Already Gone
Wow, great info..
Old 08-25-2018, 02:34 PM   #35
JHarman69c10
Awesome. Thanks
Old 08-25-2018, 08:01 PM   #36
VWNate1
VWNate1's Avatar
Post Free Advice
Most of the time you just need to include a clear, well lit photo of whatever you're asking about, there are plenty of us here who are Geezers that know and love the i6 engines .
-Nate
Geezer
1969 c-10, 1969 c10, hazard switch, steering, suspension
