10-12-2010, 08:56 PM | #26 |
Re: What is a 383 stroker and how do you build one?
im thinking about saving up and getting one built. what is a good carb/manifold set up for them?
........................ __ ............._______|__\____ ............|_({})______({})] ................(O)..........(O) |
10-13-2010, 08:46 AM | #27 |
Try a 406, you'll be glad you did. There's no replacement for displacement!
10-14-2010, 01:23 PM | #28 |
I invested around $1800 on mine. rotating assembly and labor only.
10-14-2010, 01:26 PM | #29 |
for a street motor with good heads and cam, a good dual plane should suffice and about a 750 carb. Just about every build I've seen has been in that range, and is what mine is going to have.
Project Bad Karma |
10-14-2010, 01:30 PM | #30 |
My bottom end assembly was $800 from summit, including flexplate and balancer. $120 to clean and bore the block (didn't need decking or line honing).
Project Bad Karma |
10-14-2010, 02:02 PM | #31 |
You got a mag, pressure test, bore, hone and pistons hung for $120?
That's the deal of the century... |
10-14-2010, 02:07 PM | #32 |
My kit was $900 from JEGS, $400 labor and $150 for the machine work, forgott to ad the dam cam and lifters somewhere around $250
10-14-2010, 02:19 PM | #33 | |
my cam with lifters will be $200, throw in a roller timing chain at $25-30 or so. I also bought ARP main bolts @ $23 (2-bolt block). I'm assembling the motor all myself as well, so I'm saving on labor there. I did buy new micrometers (no plasti-gauge here...), dial bore gauge and a dial indicator with mag base. All of which I can use for the next build of course. All told, I will have about $3800 in mine; just under $4600 including all the tools and such that I bought (including a new collapsable hoist from Jegs). That includes all new bolts, carb, manifold, sealers, gaskets, etc. I got a set of used headers for $100 and I am reusing the oil pan. Still debating on whether to get a new distributor or just put a good coil and cap on mine.
Project Bad Karma Last edited by pockets; 10-14-2010 at 02:28 PM. |
10-14-2010, 02:34 PM | #34 |
It aint cheap but boy they are sure fun to drive.
10-14-2010, 02:51 PM | #35 |
i'm sure looking forward to it! My brother-in-law and I have a bet on whether the tranny or rear end gives out first
I'm going to try to baby it a little bit until I can get a new tranny sometime this winter, but I have a heavy foot, so who knows. He asked me if I was going to take it to the track after I got it in. I told him I would if he would follow me with his wrecker to tow it home when I break something...
Project Bad Karma |
10-14-2010, 02:51 PM | #36 |
Makes sense; thanks for the background.
Precision tools aren't all that expensive and I wish more folks would spend the money on them like you did. A set of mic's and a bore gauge, all good to .0005, are only around $450. They're not the top notch ones...but they work fine if kept calibrated. I buy all that stuff from Goodson (www.goodson.com) Last edited by Ticker; 10-14-2010 at 02:51 PM. |
10-14-2010, 02:59 PM | #37 | |
can you post a link to exactly what you are talking about with the kit? |
10-14-2010, 03:14 PM | #38 | ||
Project Bad Karma Last edited by pockets; 10-14-2010 at 03:16 PM. |
10-14-2010, 05:58 PM | #39 |
This thread is good, I love me some sbc's, especially strokers. Not to stir the pot but if money, horsepower and reliability are chief concerns then LSx motors ARE a savior. I've built mild small blocks for $3-4K and not been too impressed. This 5.3L I picked up for $500 plus about $1500 in bolts ons, cam, springs, pushrods and she'll go about 360-380 at the crank. I could have saved $500 if I didn't have to have the fancy valve covers and LS1 accessories.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
10-14-2010, 06:45 PM | #40 |
Definitely agree that LSx > GEN I or GEN II...right up until the point you have to put them in the car
But certainly the LS swap engine mounts, headers, etc. are getting better, more readily available and cheaper and I suspect in another few years the GEN I just won't be a contender any more. I've said at least 5 times now that I'll never build another GEN I engine (I build about 10 engines/year for friends) but I keep getting requests... Now...a long stroke, long rod LS stroker is a mean thing indeed :-D |
10-14-2010, 08:52 PM | #41 |
$120 sounds about right for a bore & clean. Still wondering if that included a wet mag. And hopefully you got the rods checked - both for straightness & roundness. Personally, I'd opt for a new set of rod bolts at least. Naturally the rods will have to be re-honed afterward.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed. Last edited by GRX; 10-14-2010 at 08:52 PM. Reason: typing ........ |
10-14-2010, 09:57 PM | #42 |
Man, I wish I had a shop that did those prices.
Around here, a clean and mag goes for around $150 and a bore and hone with plates goes for about $250. I generally figure about $500 for a stock build and $750 for a performance build for machine work...plus around $300 or so for balancing if the build warrants it. Last edited by Ticker; 10-14-2010 at 09:58 PM. |
10-15-2010, 12:46 AM | #43 |
Friend of mine runs a machine shop. I bought a good 4 bolt block from him, had ALL the machine work done to it, 0 decked, bored soft hone, mag, balanced, blah blah blah for 200.00 with no receipt. (includes the price of the block)
I would never put together a motor without checking everything myself whether I knew the machinist or not. How many of you actually check the rod to cam clearance...even with stroker rods and bolts? If you are a new builder just starting out you need ot know what to do and how to do it if you are going to check your machinist...and I have seen the majority all mess up at one time or another. We are all human. Youngbuck, to answer your question about carb and manifold choices, the motor has to be considered and picked out as a whole...a complete unit as it were. When you start picking out 1 piece at a time you will get a motor that runs like one piece at a time. As a guideline for the street...err on the side of small. YOur less likely to be disappointed.
In the beginning of a change, the patriot is a scarce man, brave hated and scorned. When his cause succeeds however, the timid join him , for then it costs nothing to be a patriot. I am a revolutionary...so my son can be a farmer...so his son can be a poet. If there must be trouble, let it be in my day, so my child may have peace... 72 short step w/ 388 /4l80e/ and 3.08 gears. Last edited by llowlife; 10-15-2010 at 12:53 AM. |
10-15-2010, 09:51 AM | #44 | |
I learned this hard way with my first overhaul where the shop gave me a .010 under crank...and .020 under bearings. |
10-15-2010, 11:00 AM | #45 | |
Project Bad Karma |
10-15-2010, 11:02 AM | #46 | |
The guy I went to is a one map shop however, so he has less overhead than a bigger place.
Project Bad Karma |
10-15-2010, 11:03 AM | #47 |
I agree. Even the magazines say to double check all their work anyway, so a good set of measuring tools is just a safe investment.
Project Bad Karma |
10-15-2010, 11:10 AM | #48 | |
The new stroker rods only take a light clearance on the block - but it's still very important to check the rod-to-cam clearance with anything over about .550 lift. OEM-type (non-capscrew) rods take a fair bit of clearancing, and you absolutely, positively need to check the cam clearance. Maybe a little OT, but these things get a heck of a lot more critical on a 396 SBC stroker...but honestly I'm not a big fan of that combo; way more money and effort for a lousy 13 cubes. I've built a couple of these, and for both of 'em I got nervous and put a couple of inches of Hard Blok in the bottom of them. |
10-15-2010, 11:14 AM | #49 | |
But many of the later model blocks are in great shape, and often have virtually no bore wear. The days of doing a bearing, dingleberry hone and re-ring are way over for the older GEN I's...but I've torn down a couple of the newer Vortecs where that's what we did along with a cam change and made some very nice number at a VERY low price! |
10-15-2010, 11:38 AM | #50 |
I agree pretty much with all you said. If I had of gotten a summit block I would have had it checked with my pistons just to make sure, and with a GM block, it would have been bored .03 over anyway
My block is an 86-88 block, so not as old as a 60s/70s
Project Bad Karma |
